rear shock replacement
To make it easier to come out without slapping in face, compress springs enough for the bolts to slide out. It can be done without compressing, you have to get car up so you have a lot of drop then springs will clear. Usually in driveway compress, on high lift axles will swing down low enough to take off compression.
thanks for the info. I'm going to take care of it this weekend. On an unrelated subject, does any one know of an inline fuse that jag put in for there audio/radio? mine after market deck completely shut down on me. all the fuses I can find are good and, all interior electrics work. again thanks in advance, joe
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
