Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
rear shock replacement
Old Jun 12, 2014 | 06:14 AM
Joey T's Avatar
Default rear shock replacement
I am planning to replace rear shocks on my '85 xj6. I was wondering if any one has any insight on the procedure?
Old Jun 16, 2014 | 10:42 AM
Jagfixer's Avatar
Hardest part will be compressing springs. Not a real difficult job, just takes a lot of time. Replaced shocks on 12 and 6 took a few hrs. Put Konis on 12 and bilstiens on 6.
Old Jun 17, 2014 | 06:18 AM
Joey T's Avatar
Thanks, Jagfixer One other thing, should you compress the springs before you take out the shock or will they come out as a unit and compress after?
Old Jun 18, 2014 | 09:15 AM
Jagfixer's Avatar
To make it easier to come out without slapping in face, compress springs enough for the bolts to slide out. It can be done without compressing, you have to get car up so you have a lot of drop then springs will clear. Usually in driveway compress, on high lift axles will swing down low enough to take off compression.
Old Jun 19, 2014 | 08:01 PM
Joey T's Avatar
Default rear suspention
thanks for the info. I'm going to take care of it this weekend. On an unrelated subject, does any one know of an inline fuse that jag put in for there audio/radio? mine after market deck completely shut down on me. all the fuses I can find are good and, all interior electrics work. again thanks in advance, joe
Old Jun 21, 2014 | 05:31 AM
Joey T's Avatar
I found the audio in-line fuse under the drivers ash tray. It was only 2 amps. replaced it with 10 amp fuse to match the after market stereo.
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
AustinS '76 XJS
Sep 4, 2015 12:36 AM
aquifer
Aug 29, 2015 04:54 PM
dpappyp
Aug 27, 2015 06:31 AM
