Help....trunk won't open - RESOLVED
Old Jul 27, 2014 | 10:17 PM
kajunkooker's Avatar
Default Help....trunk won't open - RESOLVED
[2006 X-Type - added by GGG]
My doors used to make a loud locking noise when I drove over 5 mph. Now I do not hear this noise and now my trunk/luggage compartment will not unlock. This happened at the same time. Can anyone help me out with this problem? Is it something I might have done? HELP!
Last edited by GGG; Jul 29, 2014 at 03:10 AM. Reason: add RESOLVED to thread title
Old Jul 27, 2014 | 10:42 PM
I can't help with your trunk, but someone will be along to direct you tot he correct section that can.
I'll just say Welcome from ElinorB.
Old Jul 27, 2014 | 10:44 PM
avt007's Avatar
What year and model?
Old Jul 27, 2014 | 11:43 PM
o1xjr's Avatar
Welcome to the forum
Old Jul 28, 2014 | 02:13 AM
Welcome to the forum kajunkooker,
I've moved your question from New Member Area - Intro a MUST to X-Type forum. Members here with the same model will be able to help.
Old Jul 28, 2014 | 02:33 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Welcome to the forum!
Since the auto-lock mechanism quit working, and the trunk lock is inoperative, I would suspect simply a blown fuse.
That said, there might be a reason the fuse blew, but one step at a time: check and/or replace the fuse!
"In Left Hand drive cars, the internal fuse box is tucked away on the drivers side roughly where your left knee will be when you drive, it's a little difficult to find, you will need a torch."
The above statement was written by an Englishman I believe. Don't use an honest-to-god "torch" as he instructs, but rather a plain 'ol flashlight!
You'll want to check and/or replace fuse "F24", a blue 15 amp fuse.
I sure hope the $1 dollar fix does ya!
Old Jul 28, 2014 | 02:37 AM
santer's Avatar
If you need to reset auto locking after fixing the fuse
To turn the feature off or on:
1) Turn on the ignition to position II so all the dash lights come on but don't start the engine.
2) Using the button on the door handle, lock and unlock the door 3 times (don't open the door).
3) Turn off the ignition.
4) Turn on the ignition to position I.
5) Using the button on the door handle, lock and unlock the door 3 times (don't open the door).
6) Turn off the ignition.
7) Turn on the ignition to position II but don't start the engine - a beep will sound.
8 ) Lock and unlock the door once as before - a confirmation beep will sound.
From here
Turning off auto locking on x type
Old Jul 28, 2014 | 04:22 PM
2006 x type red
Old Jul 28, 2014 | 10:08 PM
Got it taken care of this afternoon. It was a fuse. Thanks to everyone for the help!
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
BadKat174
May 26, 2023 12:29 AM
findre
Sep 10, 2015 05:46 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
