'02 X-Type 3.0 misfires, but runs perfectly on an empty tank
Old Aug 27, 2018 | 07:43 PM
XeroTheory's Avatar
Default '02 X-Type 3.0 misfires, but runs perfectly on an empty tank
Hi everyone, newish user here. I recently rescued a 2002 X-Type from being hauled off to a junkyard, and have been slowly working through all of its issues and quirks. So far, I've done the following:
- Replaced water pump, belt, and WP tensioner
- New spark plugs
- New battery and battery cables
- Fabricated wire harnesses for all 6 ignition coils
- Replaced all vacuum lines, IMT o-rings, upper intake gaskets, and PCV hose
- New O2 sensors all around
- New ABS harnesses in the front
- New ignition coils are in bound
So far, it's driveable, but it still has a misfiring issue on Cylinders 1 and 4. This causes a semi-regular flashing CEL and "Cruise Control Not Available" message, along with the 3k RPM limiter. However, this goes away completely when the gas tank is on E. Not almost E, but all the way with the gas light on E. While I'd like to solve the issue entirely (hence the inbound coils), I am absolutely baffled as to what could be correcting the problem. I've observed this behavior through 4 separate gas refills, and so far it is 100% consistent in that I can haul *** and redline it no problem when the tank is bone dry, but as soon as I put so much as a couple gallons in, its right back to limp-home mode. I've never seen anything like this in any other car I've owned or driven, and google hasn't helped at all. I just want to figure out if there's anything in the fuel system that I should keep an eye on, or if this is just some kind of fluke, since I've been scratching my head over this for a couple weeks now. Just in case it makes a difference:
- It doesn't make a difference if I'm alone or have passengers, the behavior is still the same, so I've factored out the weight difference.
- It doesn't make a difference if its 87 or 93 octane in the tank
- The car did sit for about 5 months without so much as a start up before I got to drive it home
If anyone can shed some light or even point me in remotely the right direction, I'd be super grateful.
Old Aug 28, 2018 | 12:54 AM
JagV8's Avatar
Flashing MIL = severe misfires, doing cat damage. Don't drive it if you can help it or you'll be needing one or more cats
Try OBD readings (from such as an elm327). You need live data.
Check sensors etc whose function you can grasp (not many! - ECT, IAT, fuel pressure, ...).
Check for actual & pending codes.
Also see if all OBD monitors are set (causes pending P1111) but if not (P1000) exactly which ones are unset.
Finally check fuel trims. Hot engine, parked. LTFTs & STFTs ate idle and again at about 2500rpm.
Hopefully something will be apparent.
Old Aug 28, 2018 | 06:59 AM
iownme's Avatar
your misfire codes indicate both banks have a problem.
im not sure what inbound coils are, but my suspicion for the misfires is the "fabricated harness"
Old Aug 28, 2018 | 10:07 AM
Dell Gailey's Avatar
"New ignition coils are inbound" = new ignition coils are on their way to me.
Yeah, blinking MIL/CEL means major trouble destroying components. From your posting you are continually driving it with this condition = "I've observed this behavior through 4 separate gas refills".
Old Aug 28, 2018 | 06:35 PM
XeroTheory's Avatar
Yeah I ordered a full set of 6, they're just taking forever to get to me. And yeah I know its bad to drive like this, but don't let my 4 gas station visits throw you off. With the gas mileage holding steady at a solid 11.2 mpg, I've never put more than 2-3 gallons in the tank since I'd rather not waste gas. When I do drive this car to work, its a very mild 6 miles round trip, so I'm hoping the damage is at a minimum. And with this being a $300 car, I'm not throwing big bucks at it until I'm sure the problems can be fixed. I've stuck to used parts for nearly everything and if they end up resolving the issues, I'll slowly upgrade to OEM spec over time.
Aww, I'm no master electrician, but I've rewired my fair share over the years. The entire front bank had a lot of bare wire and corrosion and the back was cracking if I moved it around a bit, so I cut the connectors off and spliced in some fresh wire with new insulation and heat shielding. It sorted out a misfire I had on cylinder 2, but 1 and 4 are still at it which is what led me to purchase ignition coils.
6 miles round trip 3-4 times a week. I'm keeping it to as little driving as possible, but I have no idea how much the previous owner abused it before calling it quits :/
You aren't joking, there's not a lot to work with. I'm using Torque Pro, and all I could gather is my fuel pressure stays pretty consistent at about 56 psi. My vacuum pressure was generally -9 PSI, and (very unfortunately) my fuel trim sensors are either shot or Torque can't read them, as every option was a stable 0 despite saying it was a live reading. All of this btw was with a low tank, so I'm assuming these are normal, other than the lack of fuel trim readouts, but that could be the app and not the car for all I know. Do you know how heavy Ford's influence was on their diagnostic readouts? Torque allows me to activate a slew of Ford only options, but when I tried the same thing for my Saab with GM I was met with disappointment when not a single new option did anything.
P0300, P0301, P0304, P1313, P1316, and P1000 is pending. What exactly do you mean by OBD monitors being set and unset?
Old Aug 28, 2018 | 07:21 PM
dwclapp's Avatar
XeroTheory: Just spit balling...…..A vacuum line runs from the fuel tank to the charcoal canister (above the fuel tank) to the evap solenoid (on the fire wall, by the brake power booster on US / LHD cars) to the intake manifold. When the engine is off or cold, the evap solenoid should be closed. When the engine is warmed up, the evap solenoid should open to allow fuel fumes to be sucked from the charcoal canister into the engine. Just a WAG, but I wonder if somehow a failure in this emissions system might be causing your X-Type's odd symptoms. Try this simple test: There is a vacuum line from the firewall to the top of the intake manifold, near the throttle body. Trace it back to the evap solenoid on the firewall, under the 2 electrical connectors for the Bank 1 oxygen sensors. Disconnect this vacuum line from the evap solenoid and plug it to prevent air from being sucked thru the vacuum line and into the intake manifold. Now start the engine with gas in the tank and see if it runs properly. If 'yes', then the problem is somewhere in this evap vacuum system.
Old Aug 29, 2018 | 03:26 AM
JagV8's Avatar
Torque Pro can normally read all the things I mentioned (and anything Ford is irrelevant).
Some web searches should get you more if you want it
Maybe it's running OL (open loop) - which i not good if so!! Again, it's an OBD value so easy to check.
Old Jan 24, 2019 | 01:31 AM
sima_z's Avatar
Hi,
did you solve you problem? I have exactly the same. If the fuel tank is nearly empty the engine works perfect. But in other cases the misfire happens.
I've measured high fuel pressure. So I've changed fuel pump and also pump control module. But without any effect.
I guess that problem is somewhere in the EVAP system. But I appreciate some hints.
Old Jan 25, 2019 | 12:20 PM
tfloyd01's Avatar
Have you changed the fuel filter? My 2007 runs great, most of the time, however, every once in a while it would misfire and bog down. I replaced the fuel filter and it ran great, again. There was a lot of fine dirt-like (brown) material in the filter. If it's really bad you may need to flush out the tank. Anyway, give it a try. It may not be the problem, but what the hell, it's an easy job.
Old Jan 28, 2019 | 08:01 AM
sima_z's Avatar
Yes, I've already changed fuel filter. But I expect different behavior if the fuel filter is dirty. Than the fuel pressure should be low.
Fuel pressure sensor is near the injectors. I've measured about 55 psi in the idle. I've found that normal value should be between 40 and 45 psi.
Old Feb 23, 2019 | 12:45 PM
sima_z's Avatar
I've found the root cause finally. After one year of replacing all possible parts The Fuel level sensor 2 (the left side) was damaged. Normal resistance have to be between 20 and 190 Ohms. My sensor shows me 16 Ohms. I've replaced it and everything works fine
Old Feb 24, 2019 | 08:10 AM
car5car's Avatar
My X had 3 bad ignition coils, when i bought it. If your coils are bad, they are killing your new o2 sensors. It is a good idea to diagnose first, replace parts later.
Old Feb 24, 2019 | 04:19 PM
Steve M's Avatar
So, hang on, it has 2 fuel level sensors?
One for the gauge and one for the low level light?
How would that affect the engine running?
Old Feb 24, 2019 | 11:36 PM
The sensor on (LHD) driver's side has a sensor that controls the "venturi system" gas feeding, thus attempting as best it can to equalize the fuel level left and right in the "saddle bag" gas tank for weight distribution and vehicle handling. Once the driver's side is completely depleted, it shuts off "sucking" from that side so it's not sucking excess air (only). The sensor on the actual pump on the passenger side controls the "low fuel" lamp and/or the NAV low fuel warning. That passenger side is deeper with the "reserve" in the saddle bag tank @ low level.
So a faulty driver's side sensor telling the car to do the wrong thing makes sense it could cause running problems.
Old Nov 1, 2019 | 06:07 PM
dac44444's Avatar
What was he part number of the sensor?
Old Nov 1, 2019 | 08:27 PM
https://www.partsgeek.com/gbproducts...caAlLoEALw_wcB
theoutcast13
Dec 13, 2012 09:57 PM
jimlombardi
Dec 19, 2011 07:27 PM
rscultho
May 12, 2011 04:27 PM
vdpnyc
Mar 14, 2011 08:41 PM
Norgards
Jun 30, 2010 04:21 PM
