1st check engine light...ggrrr
Old Aug 24, 2012 | 10:44 AM
iownme's Avatar
Default 1st check engine light...ggrrr
hello all
went to run errands today (engine cold) and shortly after leaving i got a PO 128 coolant temp below thermostat regulating temp code (check engine light came on)
Any idea what to start looking at or what to check?
thanks as always in advance :+)
Old Aug 24, 2012 | 11:35 AM
Fezz's Avatar
Originally Posted by iownme
hello all
Like me, I have a check engine light currently on. And the most convenient manner to take on this is to get a diagnostic scanner, and it doesn't need to be expensive. You can search online to purchase a cheap one and it will work just fine. Make sure the reviews are positive before buying it. Good luck man!
Old Aug 24, 2012 | 01:11 PM
iownme's Avatar
i have a scanner...that is how i pulled the PO128 code...never leave home without it.
Thanks Fez....NEXT...lol :+)
Old Aug 24, 2012 | 11:29 PM
mohrd's Avatar
If you aren't also getting the DTC for the coolant temp sensor, could just be the thermostat?
Old Aug 26, 2012 | 12:34 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Your Code Scanner should allow you to erase the code. Just clear it and see if it does indeed come back.
I have had a number of instances where our '02 2.5 X-Type would toss a weird code (usually shortly after launch, sometimes even in the driveway) and after clearing it, it was never to return.
A vacuum leak of any sort can be the culprit, a cold engine "stumble" can do it, a bit of mud or grease on a wheel speed sensor can drive ya nuts, a low battery - any number of things can toss you a weird code.
I have even had the car throw a code once when I was having a disagreement with my wife. (She saw it as validation that I was wrong, and that the Jag agreed)
Just try clearing it, and see if it returns.
Old Sep 3, 2012 | 04:07 PM
iownme's Avatar
so...i cleared the code and have driven it around since i last posted.
Yesterday i got the code again. It did seem like the temp gauge took longer to move.
The light came on before the temp gauge had reached its usual half way mark, i think it would usually have been up to temp by the time the light came on.
I cleared the code and it is not back yet. I am suspecting the thermostat so i just bought the complete hose and housing on ebay.
My hose has 120000 miles on it so i'll be happier knowing its replaced. price was $114 free shipping
Old Sep 3, 2012 | 07:27 PM
iownme's Avatar
just had to take a trip, and before i left i opened the hood and noticed the top radiator hose on the far left side was squashed.
I started the engine and watched the hose...it shortly returned to its original shape. I wouldn't mind betting that could be the problem?
Old Sep 21, 2012 | 07:34 AM
iownme's Avatar
I replaced the thermostat (plus housing and upper rad hose) and the code has not returned after 1000 miles....problem fixed :+)
So PO128 code=bad thermostat
Old Sep 21, 2012 | 05:56 PM
smittybizzle's Avatar
Good info here if I get this code I will do the same thank you .
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
