2002 3.0L Cooling System
Old Oct 22, 2006 | 01:21 PM
racerx82's Avatar
Default RE: 2002 3.0L Cooling System
Haven't had that problem nor have i heard anyone else.
The 2 areas i would double check is the temp sensor, left sode of engine block(i think) and the fan control relay located next to the left fan (drivers side)
The temp sensor, even though it checked out according to the scanner, may not be closing as temp decreases. Once it opens as the temp increases, it just maybe that it sticks in the open position. The scanner won't pick that up....since it won't give a trouble code.
As for the fan control relay, have your mechanic check it for the ohms resistance...that might be stiking in the open position as well, keeping your fans on longer...(the timer circuit is in that as well)
hope this helps.
________
Starcraft 2 Reaply
Old Oct 25, 2006 | 10:15 PM
racerx82's Avatar
Cool (no pun intended) :-)
________
Bmw e83
way2far
Aug 31, 2022 09:26 AM
cissdm
May 3, 2016 06:02 AM
Dicque
Sep 19, 2015 12:53 PM
1100me
Sep 7, 2015 06:26 AM
Numwen
Sep 6, 2015 12:30 AM
