2002 X Type headlight cleaners
Old Mar 18, 2014 | 11:04 AM
rockchalk's Avatar
Default 2002 X Type headlight cleaners
Brand new to this, so be patient. I just had fuel pump replaced and when I picked car up, service specialist asked about headlight cleaners and that I was missing the front mounted clip on the left side. I did not know I had such a feature and if this were true, why would there be a clip on the front facia that would be pushed off once cleaners activated. We tried half a dozen times each to get this to work and finally arrived at a combination of headlights on and pushing button at end of stalk. I watched amazed as the cleaners extended out.
So, one clip lost and right side weakly attached. Tech suggested going on Ebay Motors to find replacement and I found someone in Isreal. Basic question remains, why design something to extend beyond the facia and then cover it with a clip? Are there alternatives to the operation in Isreal??
Just one of many questions I may now have found a place for answers. Thank you for any help/suggestions.
Old Mar 18, 2014 | 12:13 PM
ken736cc's Avatar
Hi,
My 2002 X type has the washers also. I think they only activate about every 5th time that you wash the windscreen. I also lost the painted caps and I bought the replacements on E Bay. The washers seem very fussy, and they make a mess when they spray. Mine stopped working and I am OK with that.
Old Mar 28, 2014 | 09:14 PM
Stuart Beattie's Avatar
Hi Rockchalk,
I am not sure what you are looking for but hope this helps? Regards, ps they are a pain to fit good luck, Stu
Jaguar x Type Bumper Headlight Washer Jet Cover Right or Left Side Genuine New | eBay
Or
Jaguar x Type s Type Headlight Washer Cover Pivot Swivel Cruciform Pair | eBay
Ps, the above link is for aluminium clips (CRUCIFORM) AND after gently pulling them straight out, they are less reluctant in breaking again!!
Plus there are images on the same ad above and I hope that helps YOU! Stu
Old Apr 1, 2014 | 01:21 PM
moparcarlton's Avatar
Ahh yes, I never have liked that feature on any car. When I got my 02 (I bought it with a bashed in front end mind you) I swapped it all out with a lower model bumper/headlights to get rid of those darn things!
Old Apr 2, 2014 | 11:20 AM
rockchalk's Avatar
moparcarlton
Thank you for taking the time to reply re: headlight washers. My mechanic and I are searching for the wire to cut that will not result in shutting something else down
Old Apr 7, 2014 | 04:55 AM
Hi Rockchalk,
I have searched evreywhere and only found the following:
Cleaning out the bottle and parts but to do this, you have to remove the front bumper or go in from under the undertray and both areas are dodgy if the bolts are worn or rusted or if you don't have a star-shaped screw-driver head !!
Most people have an issue with blockage and the bottle can be cleared by inserting a power-washer into the bottom of the bottle and washing it out.
Others have tried a steradent (denture cleaner), tablet which has worked, but the clips on the headlight washers are a nightmare.
I admit not using mine and having once had to refit the outer clip as I hit it with a car wash brush.
I wrapped an elastic band around my finger and slowly edged the 2 pieces back together but it was difficult!!!
If I can find something more useful, I'll post again, sorry I can't help more, if were around the corner, I'd come round as I like a challenge, but I must digress though, you have to be >IN THE MOOD< Good luck, Stu
Old Apr 7, 2014 | 07:35 AM
wazrun's Avatar
Originally Posted by Stuart Beattie
Hi Rockchalk,
That's a really cool feature from the video, how you activate the headlight washers?
Old Apr 8, 2014 | 08:14 PM
rockchalk's Avatar
Default Thanks to Wazrun, Stuart Beattie, moparcarlton, ken736cc
I still am not certain if I am communicating with the people I want to, a forum person I am not, however, thank you for your feedback and suggestions.
I have owned this car for 7 years without knowing I had headlight washers. I still have not seen them work!
We also have an XJ and S Type R. Drive them less than 4,000 miles annually. Each has fewer than 60K, get cleaned with the clay bar monthly and a professional detailing semi annually. Beautiful like a women, and just as high maintenance.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
