2002 X-type not starting
Old Apr 19, 2011 | 05:38 PM
heymistay's Avatar
Default 2002 X-type not starting
Hello,
I have a 2002 x type 3.0 with 105,000 miles on it and I am in the US (California). When I turn the key all of the warning lights appear, the radio and windows work but there is no start up. There isn't a clicking noise, it sounds more like the hum of electricity. The battery tested full power at Napa. We even put a brand new battery to test just in case and still no luck. The car will start when jumped by another car, then start about 5 times after the jump but the problem will return again. The jaguar licensed mechanic advised it, most likely, was a connection issue between the ignition and starter. He had to admit he was stumped and said he never saw this issue before. Has anyone ever experienced this before? What was your solution?
Old Apr 19, 2011 | 06:38 PM
Glendoramike's Avatar
It may be that your starter has a bad spot on the armature. If you look at the schematic below you will see that there are two windings in the solenoid. The pull in winding uses the armature of the starter for a ground which it loses when the plate connects the battery to the armature. Then the hold in winding keeps the starter engaged. The hold in winding doesn't have enough pull to to engage the starter.
I have seen it where the jump start seems to fix the problem which then returns.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
cissdm
May 3, 2016 06:02 AM
Numwen
Sep 6, 2015 12:30 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
