2003 2.5 Over Heating
Old Jul 31, 2008 | 09:10 PM
Dennis's Avatar
ud
Default RE: 2003 2.5 Over Heating
Fans should come on with the A/C on..You still may have air in the system
Old Jul 31, 2008 | 09:11 PM
Dennis's Avatar
ud
There is a special burping method that requires pinching off the heater hoses while you burp the air out
Old Aug 1, 2008 | 07:40 AM
Dennis's Avatar
ud
PM me just your email if you can..
Old Aug 1, 2008 | 08:28 AM
Dennis's Avatar
ud
Good advise On both posts of Bo's
Old Aug 5, 2008 | 05:59 PM
jag_genius's Avatar
common failures are the fan modules.. and they dont sell the modules separate.. will need new fans and possibly new link harness .. comes as an assembly...they dont know why ? lol lol
Old Aug 6, 2008 | 02:45 AM
Green Machine's Avatar
I've got the same problem and in my case it is the fan control module. This is a pricey fix because you have to replace the complete assembly, called fan shroud assembly. New shrould, fans and control module. Also requires wiring harness adaptor, called link lead, to adapt new assembly to our wiring. Cheapest I've found is $316 for assembly, $77 for harness with free shipping. In the mean time I have wired in a manual switch to turn fans on when needed.
2003 2.5 Auto
Old Aug 6, 2008 | 08:54 AM
Dennis's Avatar
ud
Nelson, glad you found the root of the problem..
Old Aug 6, 2008 | 08:56 AM
Dennis's Avatar
ud
Greenie, Why do you need the adapter connector?
Old Aug 6, 2008 | 08:59 AM
Dennis's Avatar
ud
(Continued)..Don't the new replacement shrouds come with same connectors as the old one?
Old Aug 6, 2008 | 09:00 AM
Dennis's Avatar
ud
Seems like planned obsolescence to me..*******s!
Old Aug 6, 2008 | 06:11 PM
Appearently Jag has changed something to require the adapter. I don't know what that might be because I haven't seen one yet. But I've been told by everyone I've contacted that when Jag quit supplying the control module seperately that the new shroud assembly requires the adapter and it is only sold seperately.
Because of the cost which I don't want to spend right now, I'm using my jury rigged switch which is working. Just a pain in the rear, especially if I forget to turn the fans on when needed.
Old Jul 21, 2009 | 01:25 PM
patrick12's Avatar
Hey,
can you send me this instruction, please?
Poet
Oct 6, 2015 09:40 PM
xjrjag
Sep 24, 2015 10:08 PM
Roger Mabry
Sep 15, 2015 09:22 AM
Ipc838
Sep 13, 2015 03:27 PM
Darren Schermuly
Sep 11, 2015 07:55 PM
