2003 X-Type 2.1 L SE Wont Start
Old Aug 9, 2009 | 11:54 PM
ant1.0's Avatar
Test the starter to at least rule it out. Also you may want to check for any codes the ecm may have throw to narrow down the fault.
Old Aug 10, 2009 | 05:29 PM
Thermo's Avatar
Veteran: Navy
rossi, you will need to get a fuel pressure gauge. You will need to connect it to the fuel rail and with the help of a second person, when you rotate the ignition key from the OFF position to the RUN (or START) position, watch the gauge. It should jump up to 40 to 50 psi. If it stays down at 0 or only comes up to say 20 psi, then you have a bad fuel pump most likely (especially if the fuel pressure stays at 0). If still in doubt, you can disconnect the fuel line at the fuel filter and momentarily place the ignition switch in the RUN position. You should get a solid stream of fuel out. If it tends to trickle or isn't very powerful, then that confirms a bad fuel pump. If you have a strong fuel stream, then it is possible you have a bad fuel pressure regulator.
Either way, sounds like a fuel issue, not a starter or spark issue. The only thing that would lead me to believe that it isn't a fuel issue is if you get the 40-50 psi on the initial check. Then you are most likely looking at a spark issue. If that is the case, let me know and we can go from there.
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
cissdm
May 3, 2016 06:02 AM
David Thompson
Sep 3, 2015 07:48 PM
