2003 xtype bad HID ballast can i replace with aftermarket?
Old Aug 25, 2015 | 03:36 PM
brent65622's Avatar
Default 2003 xtype bad HID ballast can i replace with aftermarket?
2003 xtype bad HID ballast can i replace with aftermarket kit as a new ballast is 400 dollars US and a new kit is like 75 or cheaper ? and if i can how would i go about hooking it in to the old harness as its different from a halogen harness
Old Aug 27, 2015 | 12:12 PM
brent65622's Avatar
Nobody has done this?
Old Aug 27, 2015 | 04:28 PM
avern1's Avatar
I am a little confused. First do you have factory HID?
If so the ballast is square and turns CCW to remove.
The wiring is a plug in. You will see a slot and can use your fingernail to push the connector off.
Look on ebay for Genuine Xenon. They are a seller and the ballast fits the Jag and they are reasonable.
I just installed one on the passenger light on my 2002 x-type
Old Aug 27, 2015 | 06:52 PM
brent65622's Avatar
yes i have OEM could you link me to that ebay seller can't find them thanks for any help
Old Aug 28, 2015 | 08:16 AM
avern1's Avatar
Here is a link to the ballasts I use:
Hella Xenon HID Igniter Ignitor Mercedes BMW Audi Jaguar 5DD 008 319 10 | eBay
They had a reasonable price and free shipping. They ship priority mail and delivery is
pretty quick.
Old Aug 28, 2015 | 12:20 PM
brent65622's Avatar
Did the igniter fix yours ? I was thinking it was my ballast but an igniter would be allot better
Old Aug 28, 2015 | 01:59 PM
avern1's Avatar
Igniter and ballast is the same term there is no separate ballast like the after markets
Old Aug 28, 2015 | 05:10 PM
brent65622's Avatar
mine has a factory ballast mounted under the headlight assembly and the igniter plugs into it Factory 02 03 04 05 06 07 Jaguar x Type s Type Xenon HID Headlight Ballast | eBay like that
Old Aug 29, 2015 | 06:55 AM
avern1's Avatar
The one you are showing would work fine. Do you know for sure that it is bad. You should swap with the working light each component and see what fails. If not you might want to consider this set since it has both.
BMW E53 E60 E65 E66 E85 E86 Xenon Ballast Ignitor Igniter Set Controller Unit | eBay
fast40driver
Apr 19, 2024 07:24 AM
rudelover2
Sep 11, 2015 08:53 PM
johanasu
Sep 3, 2015 12:39 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
