2004 X type, CD Error
Old Jun 22, 2008 | 06:58 AM
Thermo's Avatar
Veteran: Navy
Default RE: 2004 X type, CD Error
Because a CD was forced into the CD player, it is very likely that damage was done to the tray mechanism of the player. So, unfortunately, without pulling the radio out, opening up the internals and fixing whatever is broken (provided you can get the pieces you need), the more likely option is simply replacing the radio.
I guess I need to ask, will the radio still pull a CD into the radio? If yes, then your most likely problem is with the laser head. If it won't pull a CD in, then you are looking at the insertion mechanism.
Removing the radio should be as simple as removing the trim from around the radio, removing the screws holding the radio into the dash and then sliding the radio straight out. Once you can access the back of the radio, undo the plugs and remove from the dash.
Old Jun 22, 2008 | 03:42 PM
FactoryJaguarTech's Avatar
The trim around hazard switch pulls out, then remove ashtray and pull blanking trim piece out. Remove the 4 30 torx screws and remove whole unit. Then there is some 20 torx screws hold audio and climate modules together.
way2far
Aug 31, 2022 09:26 AM
kelliott
May 31, 2022 05:26 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
dcvickers
Sep 2, 2015 06:14 PM
XJsc-guy
Sep 2, 2015 11:43 AM
