2005 X-Type Estate light switch issue
Old Oct 29, 2024 | 04:26 PM
mjmindling's Avatar
Default 2005 X-Type Estate light switch issue
Hello, this is Martin in Menifee, CA. My car is a 2005 X Type Estate, BRG, 110,000 miles. I'm the second owner 2016.
The main headlight switch seems to be faulty, since the lights will go off at times while driving in the dark. A dangerous situation.
My Question: How to remove the switch from the fascia panel without breaking the locking tab at the top of the switch?
If the tab does break, how to re-fasten the switch without replacing the entire panel? I have read the shop manual but the operation to
remove the switch seems risky and could break off the tab very easily if too much pressure is applied, using the shop manual as a guide.
Need to get the switch out once to clean the contacts and get the exact part number and second time, if that doesn't work, to replace the switch
with a new unit. Advice is greatly appreciated.
Martin
2005 X-Type Estate BRG
2001 XK8 Convertible Topaz
2000 XK8 Coupe Phoenix Red
Old Oct 29, 2024 | 05:24 PM
Thermo's Avatar
Veteran: Navy
mjmindling, as for cleaning the internals of the switch, I would simply disconnect the battery and run the switch back and forth say 30-40 times. If that does not fix the issue, then you need a new headlight switch. Of note, if you buy it via the internet, you need to know which version you have. There are 3. The US version, canadian version, and Scandinavian version. You really can't switch from one to the other without some wiring changes. The different switches affect when/how the lights come on. So, please pay attention.
As for the cycling of the switch, most switches have a "self cleaning" feature of them. So, cycling the switch a bunch of times, it should clean the contacts and make a good connection.
Old Oct 29, 2024 | 08:20 PM
Peter_of_Australia's Avatar
Addition: There are way more than 3 versions of that light switch: There is a Scandinavian Version, where it is not possible to ever turn off the light (this is a legal requirement there), and there is the version, which does not have that light-on-always requirement. Some switches have the auto-leveling, then there are differences with fog lights (frt./rr.) and all kinds of combinations of above. While I did design that light switch (back then at Jaguar), it is long ago, and I don't know all the details anymore, but the number I have in my head is 12: I think there were 12 different versions. And those versions were all black. Way later they introduced coloured versions, like golden, which means, that there are now even more versions.
PS: Plus, there would be heaps more versions, if I would not have been able to convince Geoff Lawson back then to agree on a symmetrical design of the light switch - because the initial design-intend was to have also different version for LHD and RHD, which would have driven up the number of variants substantially...
Old Oct 30, 2024 | 07:29 AM
mjmindling's Avatar
Hello Thermo,
Thanks for the advice regarding X Type light switch issues.
Will let you know how this works on my car.
Martin
Old Oct 30, 2024 | 07:31 AM
mjmindling's Avatar
Hello Peter,
Thanks for the data.
If nothing else works (see Thermo) I will be removing he switch to see the part number.
My concern is to break off the clip which is part of the fascia.
If it breaks during this procedure, I'm going to be looking at some kind of repair to re-install the switch.
Will let you know how it works out.
Martin
Old Oct 30, 2024 | 05:30 PM
Dell Gailey's Avatar
Old Oct 30, 2024 | 07:51 PM
Thanks Dell, for adding this video.
I was just about to look for it myself.
I vaguely remembered that it works somewhere along those lines - it was just too long ago for me to remember fully.
The light switch in the video is without the leveling switch and without trip computer - this is why there are so many versions, but LHD and RHD switches are the same.
@MJMINDLING: Let me know, where the fault was. I am kind of hoping that it is not in the switch - I'd rather see cable or connectors as possible suspects...
Or...: ...and even that is not unheard of: Maybe it is the incandescent lightbulb of the headlight itself: It is possible that the filament inside of the lightbulb is broken thru, but from time to time the 2 loose ends reconnect...
Old Oct 30, 2024 | 08:31 PM
mjmindling's Avatar
Hello All,
First, many thanks to Dell for the helpful video.
I am hoping that my switch is mounted the same way as yours. I'm going to work on it next week, but in the meantime, I'm referring the Haynes X Type handbook.
There is a picture in the handbook of the switch, indicating a tab, or plastic extension, from the dash panel which can be pushed down with a screwdriver to release form the dash.
If it ends up having the same fastening device as Dell's video, I'd be pretty happy so as not to push down a 19 year old plastic tab and break it, this causing problems with
re-installing the switch.
Steps will be 1.) figure out which fastening method was used in my car, 2.) take out the switch very carefully, even if it is the molded tab type, 3.) try cleaning the terminals and using the method of working the switch mechanism 40 times, retry the old switch to see if I can get solid night time lighting, 4.) at the same time, get the parts number from the switch and expect to purchase a new one if nothing else works.
On a recent drive from the desert where I live to San Diego, came back after dark and was shook up well enough by the headlights and dashlights suddenly going dark multiple times and only coming on after vigorous working of the switch. Not the thing to have happen on the 5 freeway at night, surrounded by crazy S. CA drivers with no fear filters.
In conscience, I could net even sell the car with this fault because someone will be injured.
Best Regards,
Martin
2000 XK8, 2001 XK8, 2005 Estate: Previously 65 E Type, 66 E Type, 59 Mark IX, 67 S Sedan, 67 420G, 87 XJ6 VDP, 76 XJ6C in Chicago, Hong Kong, Oregon, So CA.
Old Oct 30, 2024 | 08:42 PM
mjmindling's Avatar
Default pic of X Type
Second owner, BRG, this taken in Ohio.  Car came from Florida and is now is So. Ca.  Martin
Old Oct 30, 2024 | 09:28 PM
Ah, its ALL lights, not just one. OK, then it's not the filament, but it could still be a faulty wire or connector
Old Nov 15, 2024 | 12:18 PM
mjmindling's Avatar
Default xk8 blank key buy and cut
Hi, this is Martin in Menifee, CA.
What is a good source to buy the blank ignition key for my 2000 xk8 and who can cut the key to specs?
I have one key now, but lost the second set.
Is there an id number or key code on the set which would be required to cut a new blank?
Old Nov 22, 2024 | 02:35 PM
mjmindling's Avatar
Hello Peter,
Thank you for the informative data regarding the X Type master light switch.
Good to know you were with Jaguar. I have owned Jaguar cars for 55 years!
My 2005 X Type Estate has a faulty master light switch - the lighting will go off at night, very dangerous.
Have pulled the actual switch and I'm having trouble matching the numbers on the switch with available replacements:
Numbers are: 4x43 11654
D3 LOA
0129 26 0105 241 833
Do you have any data on how to find the right replacement?
Many thanks
Martin in California
Old Nov 23, 2024 | 08:33 AM
Thermo's Avatar
Veteran: Navy
mjmindling, I would say to look on e-bay and do a search for "2005 jaguar X-type 11654". You should get like 20 hits From there, you are looking for something that has the same switch set up that you have in your car (ie, some have the trip and A/B switches on the bottom, some don't). I would also look again at your headlight switch as you should have 2 letters at the end of the part number (ie, 4x43-11654-XX where XX is those 2 letters I am talking about). Those two letters are a version number and if you get something close to what you already have, you are more likely to get something that will work with no issues. I would also tend to stay away from the "1X43" switches as these came from early 2004 and before cars. They may work, but if you are going to have a problem with wiring changes and whatnot, those are going to be most likely to have that issue.
jim_63219
May 18, 2023 04:42 PM
Kevin richradson
Jul 26, 2021 10:51 AM
kstevusa
Aug 25, 2016 05:03 AM
Daysleeper224
Sep 24, 2014 04:16 PM
pdowning6
Dec 10, 2010 03:51 PM
