60K service?
Old Feb 14, 2008 | 10:30 PM
scubayachts's Avatar
Default 60K service?
Hey everyone. My 2.5 is just over 60K miles and I was wonding what was involved in the 60k service? Also if anyone knows the cost and what not, that would be great! Thanks
Old Feb 14, 2008 | 10:58 PM
pu5hkar's Avatar
Default RE: 60K service?
I 2ND THIS MOTION.. WHAT IS REQ?
Old Feb 14, 2008 | 11:35 PM
jvegas's Avatar
a simple search would have turned up this: https://www.jaguarforums.com/m_1103/tm.htm
Old Feb 15, 2008 | 10:09 AM
I did try to search. I must no have put in the right words?
Old Feb 15, 2008 | 10:20 AM
ancientsanskrit's Avatar
Just walk into the dealership with your butt-cheeks opened! At least demand for a complementary reach-around. That or diy.
Old Feb 15, 2008 | 04:54 PM
XHIBIT A's Avatar
I just got back from the dealer and they gave me a price list for all of the services. Here is what they list for the 60k service, which is slightly different from the information listed in the link above. Per the service rep, these prices are the same across the US for all Jaguar dealerships (except for the sales tax).
For 2003 to 2006 X-Types, the total cost for the 60k service is $431.41. The breakdown is as follows:
Time: 2.4
Parts: $129.22
Labor: $265.91
Tax: $9.69
S/S: $26.59
For 2002 X-Types, the total cost for the 60k service is $464.99. The breakdown is as follows:
Time: 2.5
Parts: $148.50
Labor: $277.59
Tax: $11.14
S/S: $27.76
Now, for what the service involves:
[ul][*]Check/top brake fluid, coolant, power assisted steering fluid, windshield washer fluid, andbattery electrolytelevels[*]Check drive belt tension wear indicator(s)[*]Visually check engine compartment for leaks[*]Replace pollen filter[*]Check spare tire in trunk[*]Replace engine oil, filter and drain plug washer[*]Inspect break pads for wear; check rotor condition on pad change[*]Visually check underbody for fluid leaks[*]Check tire pressures[*]Perform comprehensive road test; verify parking break operation[/ul]
That's about it. I hope that this information helps some of you. However, the service rep that I dealt with today took me outside and recommended that I just come in for oil changes and allow them to perform the FREE Jaguar 27-point courtesy inspection each time. He said that it covers pretty much everything above and will only cost $59.95 for the oil change. Just an FYI!
Old Feb 15, 2008 | 05:09 PM
FactoryJaguarTech's Avatar
If you are paying 2.5 hours for a service, I need to go work there. I think we get 1.3 for services.
60k should include fuel filter replacement.
Old Feb 15, 2008 | 05:18 PM
XHIBIT A's Avatar
According to the paperwork that they gave me, it says: replace fuel filter (all models except X-Type) at 60k miles; replace fuel filter (X-Type models only) at 70K miles. However, you are the professional one here. I'm a Social Worker, so I don't know a whole lot about cars.
Old Feb 15, 2008 | 07:27 PM
Now, for what the service involves: [ul][*]Check/top brake fluid, coolant, power assisted steering fluid, windshield washer fluid, andbattery electrolytelevels[*]Check drive belt tension wear indicator(s)[*]Visually check engine compartment for leaks[*]Replace pollen filter[*]Check spare tire in trunk[*]Replace engine oil, filter and drain plug washer[*]Inspect break pads for wear; check rotor condition on pad change[*]Visually check underbody for fluid leaks[*]Check tire pressures[*]Perform comprehensive road test; verify parking break operation[/ul]
I'm sorry but are people really shelling out that much money for those items listed? (Nods head in disgust). Come to my place and I'll do all of including an oil change w/a long drain interval and supply you cold beers for $200! (and I'm still pocketing $170)
Sorry, but that's mind-boggling. I'm taking the standpoint that this is all inspection, if components are found to be worn, the bill immediately sky rockets.
Old Feb 16, 2008 | 05:41 AM
BuckMR2's Avatar
Fuel filter on mine was changed at 70k as per the Jaguar maintence schedule sheet.
Was absolutely minging so wont be leaving it as long next time.
Old Feb 16, 2008 | 09:26 AM
Dennis's Avatar
ud
I fell sorry for folks that can't DIY on stuff like this and depend on the Dealer to hose them...Dirty shame too, that they charge $500 for mostly inspections.[:@]
Old Feb 16, 2008 | 12:24 PM
housegroove77's Avatar
I am glad i read this post cause i am at 55000 on my X and was going for the 60k service this summer. I am amazed at the cost for someone to look at things?
Old Feb 16, 2008 | 12:29 PM
SpartanX's Avatar
Oil change costs me $38.
Joachim1167
Nov 7, 2020 09:18 PM
bdboyle
Sep 16, 2019 05:58 PM
JTC3400
Sep 29, 2015 05:03 PM
Markus
Sep 28, 2015 01:55 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
