ac clutch bypass
Old Jul 27, 2008 | 06:42 PM
aandy767's Avatar
Default ac clutch bypass
2002 xtype 3.0l
Changed dryer, o tube, compressor, and flushed.
Held a vacuum ok, so i started to charge.
Can't find the pressure switch to bypass so the clutch with engage.
There is a switch on the high side, to turn the fans on high.
The switch may be on top of the compressor but I can't find anything else.
Thanks Andy
aandy767@yahoo.com
Old Jul 27, 2008 | 08:34 PM
Thermo's Avatar
Veteran: Navy
Default RE: ac clutch bypass
Open fuse/relay box under hood, remove the compressor clutch relay, install jumper between pins 3 and 5 and that will cause the clutch to be engaged at all times.
Chris "Thermo" Coleman
Old Jul 27, 2008 | 08:41 PM
aandy767's Avatar
I pulled r6 out and looked at it. Scratched my head. Came in here and posted.
Thanks I'll give it a try.
Old Jul 27, 2008 | 09:17 PM
aandy767's Avatar
no joy,
jumped 3 to 5. that's what is printed on the side of the relay also. 3 and 5 are the long ones right?
poked a volt meter into the red wire to clutch and grounded black to the case and no volts.
The rebuild shop put the plug forward on the compressor not on the top. the only thing I can think is to pull it and see if the wires to the plug are in good shape.
they were working fine when I puled the compressor the first time.
Any more thoughts?
Andy
Old Jul 28, 2008 | 09:22 AM
Dennis's Avatar
ud
Maybe the fuse..
Old Jul 28, 2008 | 09:17 PM
aandy767's Avatar
IT's THE FUSE
Compressor was running when I pilled it. So, it's the last place I looked. Must have shorted it out. But I don't know how.
Thanks Guys
Old Jul 28, 2008 | 09:18 PM
aandy767's Avatar
Blows real cold too
Old Jul 28, 2008 | 09:26 PM
Thermo's Avatar
Veteran: Navy
Andy, if you pulled the relay under load, you current spiked the circuit as you pulled the relay. Not a big deal. Just not the best way to do things. Atleast things are working now.
ryan_border
Dec 23, 2015 04:27 PM
dan102877
Sep 29, 2015 06:47 PM
magmedia
Sep 28, 2015 09:49 PM
tonyforman
Sep 10, 2015 07:23 PM
