Advice on DIY removal of front subframe
Old Jan 7, 2018 | 09:12 AM
dh53's Avatar
Default Advice on DIY removal of front subframe
Has anyone done this without all the special alignment tools, measurement tools, and Jag specific subframe jack in the JTIS procedure? Would love to hear from anyone with experience trying this at home. Thanks!
Old Jan 7, 2018 | 03:13 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...removal-10670/
Old Jan 8, 2018 | 07:48 AM
dh53's Avatar
Thanks for that. I am not looking to remove the engine and/or trans, just trying to replace the firewall side catalytic converter so am hoping this can be done with less disassembly than jfenly went through. Anyone replaced a rear catalytic??
Old Jan 8, 2018 | 01:57 PM
avern1's Avatar
It is a bit of a chore but if you have access to a lift it can be done in place.
Remove the upper intake manifold for access. Soak the bolts good in rustbuster and make sure everything is cold. Removing intake bolts hot will just about guaranty the inserts will pull out that the bolts screw into.
BugDoc
22
Mar 11, 2021 08:47 PM
GordoCatCar
May 11, 2019 04:54 AM
Asdrewq
May 16, 2017 08:00 AM
Daim
Jan 26, 2017 01:13 PM
310jag
Feb 5, 2009 03:52 PM
