Amber engine warning light.
Old Jun 30, 2012 | 03:27 PM
jewelsandchris's Avatar
Default Amber engine warning light.
On motorway today and suddenly felt a 'thump' followed by the engine power reducing and stuttering. Slowed right down and came off at the next exit. Switched the engine off and got the handbook out. States the waring light indicates an engine problem and has put the engine in 'limp home mode ! '. We decide that we would 'limp' home and drove slowly the remainder of the journey not going above 60mph. The car seems to be running as smoothly as it was before but the warning light is still on. Nothing obvious in the engine bay (oil etc) but i'm no mechanic. All the oil/coolant levels are fine. Any idea's anyone ?
ta in advance.
2002 2 ltr X type manual.
Old Jun 30, 2012 | 07:39 PM
iownme's Avatar
Is it the check engine light or the amber lozenge shaped light?
Old Jul 1, 2012 | 02:20 AM
Hi iownme, thanks for replying.
Its the engine shaped amber warning light. It ran sweet as a nut after switching the ignition off for 5 minutes and re-starting. I would have put it down to a faulty dash warning light but for the 'thump' and loss of power when it happened.
Old Jul 1, 2012 | 05:13 AM
Checked the car this morning with the engine cold, coolant a little low although no obvious leaks, topped it up. Engine oil fine, not discolored. Started first time and sounds smooth, revs smooth but warning light still on :-(
Old Jul 1, 2012 | 06:57 AM
iownme's Avatar
You can have the codes read @ most auto stores for free...that is the first step. We need to know what the fault codes are.
I suggest buying a code reader to keep in the car...u don't need an expensive one...spend around $30-$60. Its an important tool to own..even if u don't work on the car yourself.
Get the codes and post back with them
Old Jul 1, 2012 | 06:59 AM
iownme's Avatar
If you decide to buy one..ask for an OBD2 code reader
Old Jul 3, 2012 | 01:27 PM
Checked out by garage today, came back no faults found, codes re-set, warning light extinguished ....... its a mystery ! :-)
Old Feb 7, 2019 | 06:49 PM
Harry Peter Rose's Avatar
X-series 2002 auto AWD 2.5 Petrol 66,000 miles on going problem for 3 months {jag/trained mechanic unable to resolve} all the usual replacement done sensors etc both banks fuel injectors /engine decarb/internal combustion chamber cleaning infold manifoldEngine warning light /with occasional amber which comes on driving around 70 mph stays on for a few miles then does not come on again until parked and journey resumed after same type drive as above......very occasionally accelerator resisting pressure of my footCODES P0170 PO174 CLEARED 4 TIMES.... COME BACK ON AFTER DRIVING AS ABOVE!.. ANY THOUGHTS APPRECIATED1
Old Feb 8, 2019 | 01:57 AM
JagV8's Avatar
You don't need to multi-post.
https://www.jaguarforums.com/forum/x...1101-new-post/
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
RoyLittle0
May 25, 2023 02:38 AM
Jpav27
Jul 31, 2022 06:43 AM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
