Any way to fix this?
Old Jun 6, 2011 | 05:39 PM
rhriczko's Avatar
Default Any way to fix this?
The headliner and the trim around my sunroof seem to be separating. Does anyone know the cause of this? Is this common? Any help would be appreciated, its very annoying and is continually getting worse.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jun 6, 2011 | 05:57 PM
guest2's Avatar
Had the same problem. just take it to someone that does car seats covers and they can put in a new head liner for a few hundred dollars. No big deal it take a couple of hours.
Old Jun 6, 2011 | 06:12 PM
Tec Nine's Avatar
get some 3m adhesive and u should be able to fix it yourself
Old Jun 6, 2011 | 06:49 PM
rhriczko's Avatar
Thats what I was thinking too. The headliner is in great shape so I would hate to have to replace it. I like the 3M idea.
Does Jaguar make a new trim piece that would prevent the problem from coming back?
Also this happens only when I have the sunroof open, i forgot to mention before, could this be indicative of a larger issue? In my opinion its probably as simple as the 3M tape, but I don't want to overlook something if anyone out there has better info than I do.
Old Jun 11, 2011 | 12:43 PM
srwedd's Avatar
If the headliner only falls when the sun roof is open, I would check to see if something is pushing down on it or if it is just the wind blowing it out. If it is just the wind the 3M idea is the way to go; but if there's some pushing the headliner out then you might have bigger problems.
If you have a garage (or some place that you don't have to worry about the wind) push a the headliner up (sunroof closed) and then open it. If the headliner stays then 3M the hell out of it. If the headliner falls take a flashlight and see if you can see something stuck between the window and the roof. Best of luck.
Old Jun 16, 2011 | 03:42 PM
disguay's Avatar
Another vote for the 3m!!!
Old Jun 16, 2011 | 08:46 PM
rhriczko's Avatar
Thanks, Ill give this a try this weekend.
Old Jun 16, 2011 | 11:11 PM
Jaggyx's Avatar
3M, like mentioned, should work.
Old Aug 20, 2013 | 03:26 PM
emaraszek's Avatar
Sorry to post on an old thread, but I have the exact same issue where it appears the trim for the sunroof is separating from the headliner. Did the 3M do the job?
Old Aug 20, 2013 | 09:34 PM
Thermo's Avatar
Veteran: Navy
Evan, it has worked for me. Get yourself some 3M 77 upholstery spray on adhesive. The one thing that I would also recommend you do is to pull a little bit more of the fabric loose as the edge of the glue is drying out. So, if you just glue what is loose right now, in another year or so, you will end up with a little bubble of loose fabric that you will have to rip apart what you are gluing now to access. Using some masking tape and newpaper to cover what you don't want sprayed with glue is a good idea too.
Old Aug 21, 2013 | 12:21 PM
flyrr100's Avatar
I used industrial strength Velcro. Ran it across the whole width of the roof. Its held for a year now.
aholbro1
Dec 29, 2024 06:46 PM
Arne
Aug 18, 2024 12:08 PM
GordoCatCar
Jan 2, 2017 01:10 PM
hhv00586
Sep 18, 2015 08:59 AM
JagLove86
Sep 6, 2015 10:36 PM
