Automatic Transmission fill plug removal tool
Old Sep 9, 2019 | 06:43 AM
JagQ's Avatar
Default Automatic Transmission fill plug removal tool
Hello.
Thanks to many users in this forum, and to dell-gailey in particular, for his post lead me to making this tool, and i wanted to share it.
If anyone has posted pictures of it before, then i must have missed them,.
Old Sep 9, 2019 | 06:49 AM
JagQ's Avatar
the length of the pipe should be enough to raise above the battery, the metal bat is the same length, so when the plug is in the PVC pipe, the metal bar is out by about 8 mm, to insert it back, push on the metal handle while holding the pvc pipe in place.
The pvc pipe is a bit thick for the opening between the battery housing and the water pump driving pulley. I should make it thinner or find a thinner pipe,
However, It works without removing the battery,,,,
JigJag
May 29, 2019 08:54 PM
adenshillito
Feb 8, 2016 06:56 AM
10 XF Premium
Dec 28, 2015 09:39 PM
countyjag
Mar 18, 2015 10:40 AM
Daim
Jun 22, 2014 12:53 PM
