Blank Navigation screen
Old Jun 7, 2015 | 07:14 AM
  #401
Richard williams's Avatar
Originally Posted by Cambo
Everything you need is there.
Will try. Tnx so much you should see the joy in my heart already. Will let you know if it worked
Old Jun 7, 2015 | 07:52 AM
  #402
Hi. Burned file on dvd. Followed instruction. Nothings happening. Do I have to unzip the file you sent me or decode it?
All I did was place a blank dvd in laptop and drag and drop and burn.
Then followed I structions.
Old Jun 7, 2015 | 08:03 AM
  #403
Cambo's Avatar
the file is called loading.kwi, that's what you should see on the disc, if it doesn't work then you might have other issues...
Old Jun 7, 2015 | 10:20 AM
  #404
Hi. When I burn disc it says "non - bootable image" perhaps that's why it won't read. Which burner did you use or dvd type. Please help don't give up.please.
Old Jun 16, 2015 | 03:58 PM
  #405
Dieter Didi Niederstätter's Avatar
Hi everybody,
I have the same issue (blank screen 50/51 fault codes) on the 2001 X-Type 3,0 V6 of a friend of mine.
Tried to burn and install a loading.kwi (2011) I found in this thread but nothing happened. Even rebooting with the original Navi CD brought no success.
Is there another loading.kwi I could try? Maybe an older one than the 2011?
Thx to all of you
Didi
Old Jun 17, 2015 | 08:17 AM
  #406
Paulc732's Avatar
Here is a link to the unziped file ready to burn to a disk.
If this does not work for you chances are the DVD unit has gone bad or you have a wiring issue.
https://www.jaguarforums.com/forum/x...d-link-138788/
Old Jun 18, 2015 | 08:04 PM
  #407
Jaimie Moore Escudero's Avatar
could i get the soft ware as well... i would like to fix mine. this is such a common problem this disk should be included with the car...what a headache to have with a car with such a fine name...
Old Jul 10, 2015 | 07:54 AM
  #408
twinstacks's Avatar
OMG !! I made a complete idiot of myself. I was looking through the hidden menu in my touch screen and pressed the s/w button and now have a blank black screen and the fan going nuts. The link here to the loading.kwi I have burned to a standard dvd and put it into the dvd reader in car, turned off ignition and turned it back on again but still flashing 50.51. The link is only 7mgb in size which seems a bit small. Can someone please tell me what am doing wrong and give me the proper software for my 2004 x type.
Thanks you to everybody from a **** touchscreen breaker.
Old Jul 10, 2015 | 07:57 AM
  #409
twinstacks's Avatar
Hi. I tried to PM either solidx or factory jaguartech for help with getting the update disc. Can anyone help.
Many thanks
Old Jul 11, 2015 | 03:27 AM
  #410
JagV8's Avatar
You may well have bricked it.
Old Jul 13, 2015 | 05:22 AM
  #411
twinstacks's Avatar
Hi. from what I have read on here and various other threads if all was working before you pressed the update button you can't damage any of the hardware only the software as you have interrupted the update process and all the settings are lost. The only way to get it back is to reinstall the firmware which I am not having much luck with doing. I have ordered a new map disc with latest firmware update and hope this work.
Old Jul 19, 2015 | 05:42 PM
  #412
jjkurzbuch's Avatar
I am having the same issue issue that sold was having with his nav screen. My car is an 02 jaguar x type. Any chance you could message me the software dvd also?
Old Jul 19, 2015 | 06:36 PM
  #413
twinstacks's Avatar
The dvd is to big to email but I can take the loading.kwi off it and send you that. You need to burn it to a DVD - disc as the + ones don't seem to work.
Old Jul 19, 2015 | 10:01 PM
  #414
jjkurzbuch's Avatar
Could you send me the loading.kwi off it? Thank you
Old Jul 19, 2015 | 11:41 PM
  #415
jjkurzbuch's Avatar
Could you send me the s/w for my x type sat nav also? jjkurzbuch@wisc.edu
Old Jul 22, 2015 | 08:01 AM
  #416
twinstacks's Avatar
Hi. I emailed it to you a few days ago. Please check your junk folder
Old Jul 24, 2015 | 10:44 AM
  #417
trosty's Avatar
It would be nice if someone could either put a little video together of how to do this whole process from start to finish (including the DVD-R burning, what software used, where to get the relevant .kwi file how to burn it and then re-installing in the jag).
This is definitely one of those How To's that's needed.
Old Jul 27, 2015 | 02:51 PM
  #418
twinstacks's Avatar
I could do it but not wanting to temp fate by hitting the S/W button again to blank the screen. Sorry
Old Aug 18, 2015 | 03:41 AM
  #419
alex ross's Avatar
hey folks thanks in advance and the NAV screen is dead on my S type R 06 and been trying a few things.... I've got C1, 50, 51 messages too.
Checked the fuse (all good)
Battery reset
Removed the dvd and dvd unit to try and reset things. It won't eject and actually doesn't seem to turn on or do anything.
I can go through the diagnostics on the screen and all the buttons will work...
Thinking I'll try to replace the DVD player unit itself first.
seems like a rather common issue however just wondering if anyone has had their DVD player unit go bad? I'm guessing it's the actual nav DVD unit in the trunk? The DVD won't load or eject..
Hence the option of software update via a DVD won't work? Seems like a dead unit so I guess I'll try a replacement one first... Hoping that's all it is. Hottest day of the year in California and although I can live without a nav it'd be nice to have AC
Old Aug 18, 2015 | 05:10 AM
  #420
twinstacks's Avatar
Hey Alex
Did you do anything to make the screen go blank like press update in the secret menu. Usually when it goes dead for no apparent reason its usually the dvd player that dies and with it all touch screen and heater controls with fan going to full pelt. A few things to check. Firstly get someone to switch ignition on when you have your ear to the dvd player and listen to hear if it is doing anything at all. If nothing is heard then check the fuses to the touch screen and dvd player not with your eye but use a continuity meter if you have one on the fuses you remove to check them. If all checks out then suspect the dvd player. You say you can't remove disc which is a pity cause if you could take the disc to your pc and have a look at the files on the dvd and see if there is a .KWI file there as that's the software to work the touch screen. There are other checks but these are the basic ones. Hope this helps
