Bluetooth microphone
Old Nov 12, 2018 | 09:50 AM
rayclark1's Avatar
Default Bluetooth microphone
Can Anybody tell me if a BLUETOOTH MICROPHONE is a standard fitting in the overhead console
with an X Type 2003. Otherwise I presume one has to be fitted to allow for telephone calls - Where does connect to
in that case ?
Old Nov 13, 2018 | 11:35 AM
x_type_lpg's Avatar
the loom with the plug is in the loom, remove the over head light unit and feel around for it normally wrapped in foam to stop rattle. mic not normally fitted
Old Nov 13, 2018 | 03:36 PM
rayclark1's Avatar
Yes I had the unit detached today to confirm that no Microphone was fitted. Will revisit and see if the connector is as you say thereabouts.
Old Nov 28, 2018 | 04:36 AM
rayclark1's Avatar
I had the head unit out and did a thorough search but found no connector for the microphone. So I imagine I will have to put a cable in, if so where will it run from to connect up with mic ?
Old Nov 28, 2018 | 04:23 PM
dennis black's Avatar
ill post pics...just got to find them
Old Nov 28, 2018 | 08:40 PM
heres the microphone to get all others suck real bad
then it connects into the slot in the pic below
Old Nov 29, 2018 | 12:31 AM
rayclark1's Avatar
Dennis is this under overhead light console ? looks slightly different to mine. I will take some pics.
Incidentally still awaiting the delivery of my modified head unit before posting those other pictures we discussed earlier.
thanks
Ray
Old Nov 29, 2018 | 05:27 PM
yes it is. heres the pdf on the phone set up and where you put the microphone
https://www.drivehq.com/web/jfenley/...%20install.pdf
Old Nov 30, 2018 | 12:34 AM
rayclark1's Avatar
Good Day Dennis
Very good guide - thank you will be useful when I eventually get around to installing my entire head unit with the navigation & a droid upgrade.
I notice from the diagram that there should be a lead inside overhead console for the mic - there is not one in mine, I have investigated this area quite thoroughly -
no lead, What would be the way round this little headache ?
Old Nov 30, 2018 | 05:08 PM
first take a pic of your console and cloe ups and what plug is up there ..
Old Dec 14, 2018 | 04:12 PM
rayclark1's Avatar
Red face Illusive Creature found !
Please note all those who so ably assisted me that the Microphone connector in the overhead console has surrendered -
He was found hiding & stuck down with gum in the overhead lining. Now connected to his buddy the microphone.
Just a couple of small details to iron out and the new odroid/Navsat system is going to be installed.
RobbyHughes
Oct 17, 2018 04:06 PM
martin49315
Feb 27, 2017 04:05 PM
Joshua Brent Langford
Dec 11, 2015 03:10 PM
JT-XK
Jun 15, 2013 09:19 AM
WinterJag
Jun 10, 2010 02:08 PM
