Brake/Tranny clicking
Old Jul 12, 2011 | 09:25 PM
hdgreg's Avatar
Default Brake/Tranny clicking
Had my 2002 X-type for 2 months and love it, except for the one cupholder! However, today whenever I pushed on the brake pedal (any gear or neutral on my auto transmission) a loud click sound would come from the area of the shifter. Didn't matter whether stopped, moving, slow or fast, pushing brake pedal hard or soft....Any guesses on what this can be?
Old Jul 13, 2011 | 08:36 AM
pab's Avatar
pab
Just speaking wildly. is it the transmission/brake inter-lock? You know the change that all the car makers made to prevent the run away Audi problem...
Without your foot on the brake can you shift from P to D? ================================================
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Jul 13, 2011 | 10:34 AM
stshots's Avatar
The problem is the park lock solenoid in the j-gate. There is a switch that lets the car know its in park. Over time the contacts get dirty and it still thinks its in park when its not. The clicking is the solenoid releasing the lock to let you shift out of park. To fix it, replace the switch. Do a search on here and you'll find many posts on here about this problem. I was able to clean and rebuild my switch and its still holding 10,000 miles later.
Old Jul 14, 2011 | 09:21 AM
hdgreg's Avatar
Thanks for the info. I'm searching for a solenoid to replace mine as of now. Anyone have a good source for these? Thanks for troubleshooting my car for me. Greg
Old Jul 14, 2011 | 11:14 AM
stshots's Avatar
If its clicking, its not a broken solenoid. To replace that would not solve your problem as the clicking means that its working just fine. Its the park switch separate from the solenoid that is your problem. Some have reported that you have to buy a new J-gate just to get the switch but I'm sure with a little resourcefulness, you could find one, use something similar or just clean the one you already have. The last option (cleaning) is a little tricky but not impossible by any means.
Old Jul 14, 2011 | 07:15 PM
hdgreg's Avatar
Park switch in the j gate....My friend has a shop, but is not a jag man. But, he can order parts for me at his cost. I will see what he can do. Thank you.
Old Jul 14, 2011 | 08:20 PM
stshots's Avatar
It sounds much worse than it is. Basically you just have to pop off the trim around your shifter (pops up and off really easily), unscrew the shift knob and remove a few torx head screws under the trim. You can take the top of the shifter off really easily and the switch is right in there. You'll see it as the shifter will contact it in park. A couple of wires run to it from down below. It's really an easy job. Nothing to sweat at all.
boiler
US Southwest
Dec 20, 2025 12:38 AM
magmedia
Oct 8, 2015 03:28 PM
gunlocators
Sep 30, 2015 08:05 AM
bydand
Sep 28, 2015 09:47 AM
Long Islander
Sep 27, 2015 03:45 PM
