Broken Wheel Stud
Old May 15, 2019 | 02:14 PM
enreb's Avatar
Default Broken Wheel Stud
How do I remove a broken wheel stud from the front driver's side of my 2007 Jaguar Xtype 4dr sedan?
The wheel cannot be removed because of the broken stud.
Old May 15, 2019 | 02:49 PM
Dell Gailey's Avatar
Remove hub, brace well, pound out old stud, replace stud, fit into place by snugging tight with the nut.
Lincoln LS are same studs @ lower price usually.
Old May 15, 2019 | 03:19 PM
enreb's Avatar
The wheel cannot be removed. Can it be drilled out?
Old May 15, 2019 | 05:19 PM
Oh, I thought you posted how to replace the STUD.
S but still applicable =
https://www.jaguarforums.com/forum/s...res-fix-59396/
Old May 15, 2019 | 09:07 PM
If anyone would like to get rid of the stainless steel covered caps on the original nuts, that constantly deform using the original provided lug wrench instead of buying and keeping a proper sized 6 point socket in their trunk (boot). Or allowing shops to use impact guns that really bugger them up and WAY over tighten them. I understand these one piece nuts fit the X Type = Dorman 611-229
Old May 17, 2019 | 01:39 PM
Brian01's Avatar
Default Had the same problem with factory stud snapping
I tried using a removal tool for the broken nut but it was worse than useless, I ended up using a cobalt drill chisel and a 20 oz hammer to break up the nut, ended up damaging the thread in the hub and had to replace that as well, drilling multiple wholes down the side of the nut was very time consuming but as far as I know its about the only way to remove a snapped nut
Old May 18, 2019 | 09:04 AM
dennis black's Avatar
20 Year Member
Old May 21, 2019 | 08:15 PM
car5car's Avatar
So nut is still on? Is stud turning?
Old May 21, 2019 | 08:29 PM
Troll can't read either
ragman1171
Feb 4, 2020 09:17 PM
mferguson
XE ( X760 )
Jun 27, 2018 12:52 PM
CookieMonster
Jun 13, 2017 05:32 PM
Fernando
Sep 16, 2016 10:26 AM
the beagle
Mar 30, 2015 10:49 PM
