Broken Wheel Stud
How do I remove a broken wheel stud from the front driver's side of my 2007 Jaguar Xtype 4dr sedan?
The wheel cannot be removed because of the broken stud.
Oh, I thought you posted how to replace the STUD.
S but still applicable =
https://www.jaguarforums.com/forum/s...res-fix-59396/
If anyone would like to get rid of the stainless steel covered caps on the original nuts, that constantly deform using the original provided lug wrench instead of buying and keeping a proper sized 6 point socket in their trunk (boot). Or allowing shops to use impact guns that really bugger them up and WAY over tighten them. I understand these one piece nuts fit the X Type = Dorman 611-229
I tried using a removal tool for the broken nut but it was worse than useless, I ended up using a cobalt drill chisel and a 20 oz hammer to break up the nut, ended up damaging the thread in the hub and had to replace that as well, drilling multiple wholes down the side of the nut was very time consuming but as far as I know its about the only way to remove a snapped nut
next time use these . you would have it done in no time ,and you will save the stud
So nut is still on? Is stud turning?
ragman1171
Feb 4, 2020 09:17 PM
Fernando
Sep 16, 2016 10:26 AM
the beagle
Mar 30, 2015 10:49 PM
