a/c problem
Old Sep 5, 2010 | 11:03 AM
Dshearer's Avatar
Default a/c problem
a/c works fine on low setting , but as soon as I turn it to a certain temperature a/c blow hot . anybody know what the problem is.
Old Sep 5, 2010 | 12:54 PM
Thermo's Avatar
Veteran: Navy
Dshearer, do you notice the problem at all speeds being travelled or just when idle/stopped. If you notice it only at very low speeds/stopped, then odds are you are looking at an engine cooling fan issue. If this occurs at all speeds, then I would first check your freon level. After that, you may have a clog in your A/C system, leading to the system not being able to flow enough freon, leading to what you are seeing. As for where the clog is, hard to say. Both of these can be found if you take the car to a shop to have them give the A/C system a once over. Should be fairly cheap for them to check out the system. From there, you can get a feeling for what it will cost to correct.
Old Sep 5, 2010 | 05:34 PM
Dshearer's Avatar
the a/c work great on the "low" setting at any speed and parked. but as son as I turn it to 61 degrees or above a/c blows warm.
Old Sep 5, 2010 | 06:24 PM
Thermo's Avatar
Veteran: Navy
Dshearer, I missed the fact that you specified a temp on the controller. For some reason I was reading it as vehicle speed. My mistake. Based on it being a set temperature that it flops (should be hearing the damper inside the dash moving), it sounds like you either have:
1) temp sensor in the dash has failed and is sending the A/C system a constant 60F signal (or the associated wiring is bad), or
2) there is an internal failure for the A/C system computer, leading it to mis-interpret what the sensors are telling it, therefore leading to your issue.
Either way, it is sounding like an electrical issue. I don't know how you are with wiring, but if you want to take a stab at making things work, let me know. I'll see what I can dig up.
Old Sep 5, 2010 | 06:25 PM
Thermo's Avatar
Veteran: Navy
Oh yeah, do you have the system that is integrated into the radio or do you have the external (not built into the radio) setup? That may affect some things.
Old Sep 7, 2010 | 12:26 AM
Dshearer's Avatar
It's an 04 x-type 2.5L 5 speed. Everything is intergrated. I'm not sure if the low and high setting is controlled by the climate control. But when I turn the temp to 61 the whole a/c system turns off. The engine fan will stop and the a/c clutch also.
Old Sep 7, 2010 | 05:20 PM
Adam Lueb's Avatar
Smile AC
I would have the high pressure side and the low pressure side of the compressor checked. It could be a compressor problem
Old Sep 7, 2010 | 10:21 PM
Dshearer's Avatar
Ok the low side reads about 35 the high side is about 225
Old Sep 8, 2010 | 01:33 PM
Adam Lueb's Avatar
I don't know what the Jaguar spec are for the compressor but off the top of my head these readings seem to be OK
Old Sep 8, 2010 | 02:12 PM
sidewalkman's Avatar
I think Thermo is asking if you have NAV, or is the Radio a separate unit. Also is your unit the climatrol thing that you set the temp and then it maintains it or .....
Old Sep 9, 2010 | 05:30 AM
Dshearer's Avatar
I don't have nav. I think it must be something wrong with climate control. I read somewhere the low and high setting by passes the climate control system which would explain why my a/c does work fine on the low setting.
Rivguy
Dec 4, 2020 07:55 AM
Dicque
Sep 19, 2015 12:53 PM
Saturbo
Sep 8, 2015 07:35 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
