Can I Beat? Looks like Jeremy can.......
Old Jun 24, 2011 | 12:42 PM
ufoz8mycow's Avatar
Default Can I Beat? Looks like Jeremy can.......
I knew you thought it would be a secret... At least until I checked the site!
Old Jun 24, 2011 | 02:02 PM
exexpat's Avatar
Mike Gilbert is a photographic magician. I would send you the rolling rig shot, but then I would have to kill you.
Old Jun 24, 2011 | 02:08 PM
exexpat's Avatar
Also... with a little extra fabrication work I was able to get the nose down another 1/2" or so. Don't think that pic is completely aired out. I can barely tuck the curb guard edge fully aired down - so about 10mm from the 18" rim lip.
Old Jun 24, 2011 | 02:26 PM
ufoz8mycow's Avatar
When is the full feature going up on the site?
Old Jun 25, 2011 | 02:35 AM
Cadillac's Avatar
That's lovely
Old Jun 26, 2011 | 03:49 PM
Tec Nine's Avatar
That is killer. How did you get the extra 1/2".
Old Jun 27, 2011 | 02:57 AM
exexpat's Avatar
The bottom of the air strut now sits about 3/4" lower than the lowest part of the lower strut clamp. I still have 10mm or so to the CV boot, so plenty of clearance there. Remember I have a cylinderical sleeve of 3/16" inch steel around the strut to help bare weight - had to notch that a half inch and modify the rotational key ears to let them drop further. I'm still tucking tire (215/35/18) at 50psi - where ride quality is about ideal.
Old Jun 27, 2011 | 11:35 AM
ufoz8mycow's Avatar
I'm very aroused.
Old Jun 27, 2011 | 10:42 PM
exexpat's Avatar
Originally Posted by ufoz8mycow
I'm very aroused.
Because of moar lows or because of cylindrical metal objects moving down into clamps?
Old Jun 27, 2011 | 11:37 PM
ufoz8mycow's Avatar
moar lows
Old Jun 28, 2011 | 08:58 PM
Tec Nine's Avatar
My front struts have like an extra piece of metal welded on them where the bolt that clamps the bottom portion goes thru so they cannot drop on their own. I guess they updated them since you got them
Old Jun 29, 2011 | 12:17 AM
exexpat's Avatar
I had those pieces at one point also. A Dremel with a reinforced cutting wheel takes care of that quickly. Just don't mess with them unless you plan to put sleeves (roughly 6 inches tall) around the shock body against the lower clamp top and the end link brackets.
Old Jun 29, 2011 | 11:21 AM
Tec Nine's Avatar
Yea I wouldn't want them falling thru and hitting the axle. You have expiriance in this are correct. Haha
Old Jun 29, 2011 | 11:38 AM
exexpat's Avatar
You also don't really want the weight of your car solely on those little ears. Those are meant to be keys for rotation and not support weight. That is what I "discovered", yes.
Old Jun 29, 2011 | 07:29 PM
fabfive's Avatar
New backround on laptop = Check.
New euro front bumper moldings = FTW! makes it even smoother times a billion.
Girlfriend say's "Why don't you make your jag look like that" = Shrugs with a jealous smirk.
Just killed it Jeremy (in the good way).
Its like getting a new issue of your fav magazine when ya were a kid; Every month something fresh!
Congrats man!
Old Jun 29, 2011 | 08:00 PM
Ipc838's Avatar
You guys are right, this is the work of a talented phorogrpahist. Is it just me, or did the bolt pattern adaptors that are installed push the rims so far beyond the fender flares that the tyres mush be several series too narrow? Or maybe I'm just seeing it wrong. An interesting job I must say, idk about the tyres, I suppose I'm not as familiar with a bagged ride as many.
Old Jun 29, 2011 | 10:27 PM
exexpat's Avatar
No, they are actually Coventry Whitley in 18x9.5" ET28 front and ET23 rear. It is an XKR rear wheel fitment on all four corners of my X-Type. No adapters and it uses factory Jaguar lugs. I did need to run 215/35/18 tyres to have clearance on the front wings.
Old Jun 30, 2011 | 12:28 PM
ufoz8mycow's Avatar
Crap I didn't even notice the new bumper blades but YES way nice.
Wolfy
May 28, 2024 08:06 AM
Terry007
Mar 5, 2019 06:42 AM
08292
Nov 24, 2017 11:22 AM
tampamark
Oct 11, 2015 10:03 PM
Mbourne
Sep 14, 2015 09:21 PM
