Cannot open drivers door
Old May 7, 2018 | 05:43 AM
Kevinuk1's Avatar
Default Cannot open drivers door
Jaguar X Type 2.2 D
Cannot open the drivers door either from inside or outside with the key, the inside door handle looks like it’s in the open position and will not go back to the normal position. Any help much appreciated.
Old May 7, 2018 | 11:12 AM
avern1's Avatar
Unfortunately it is going to be necessary to remove the door card and access the mechanism. It is possible to remove the seat assembly and then remove the door card. Be sure to order some replacement fasteners for mounting the door card. They are fragile and do break. Once the card is off you can reach the mechanism and should find a rod that has to be press downward to release the latch.
Old May 7, 2018 | 06:16 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...en-all-197561/
Digital Will
Feb 21, 2026 05:58 PM
JimC64
Sep 22, 2025 02:52 PM
iownme
May 27, 2017 09:38 PM
john_cook12
Oct 8, 2016 12:18 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
