Check engine light and 2 codes??????????
Old Jul 30, 2008 | 02:53 PM
hankycbr's Avatar
Default Check engine light and 2 codes??????????
Hello Everyone,
all of a sudden my check engine light came on with these 2 codes:
1) P1647 and P1000
I tried to look it up in this forum but I could not find anything. Anyone have any ideas? the car is running.???
thanks!
Old Jul 30, 2008 | 03:17 PM
DZtt's Avatar
Default RE: Check engine light and 2 codes??????????
Not sure if it's correct, but a quick google search showed P1647 as possibly your o2 sensor.
Old Jul 30, 2008 | 03:36 PM
hankycbr's Avatar
Thanks. I am looking in Google as well. The strange thing is that my mechanic said it was originally the o2 sensor before (2 weeks) ago but now that is gone? I am confused.
Old Jul 30, 2008 | 04:04 PM
Thermo's Avatar
Veteran: Navy
p1647 is your bank 2 upstream O2 sensor bad. Most likely the sensor itself. Unlikely, but possibly wiring. Chris "Thermo" Coleman
Old Jul 30, 2008 | 04:07 PM
Thermo's Avatar
Veteran: Navy
P1000, system test not complete since last memory clear, nothing to fix. Chris "Thermo" Coleman
Old Jul 31, 2008 | 09:03 AM
hankycbr's Avatar
Hello Thermo, thanks for the help. I believe this bank 2 upstream O2 sensor is my next step.
Any idea how much this part and labor should cost me roughly? is this an easy job?
thanks in advance!
Old Jul 31, 2008 | 09:25 AM
hankycbr's Avatar
in another post JagGenius mentioned that bank 2 is the easiest to replace. is this the same one?
do you guys recommend buying original jaguar sensor or buy aftermarket?
thanks!
Old Aug 1, 2008 | 07:01 AM
Thermo's Avatar
Veteran: Navy
Hanky, the part (Bosch OE type) part is $84 at Schucks/Advance/Kragens. To replace, probably looking at 2 hours at most. Requires a special socket wrench.
Old Aug 1, 2008 | 01:47 PM
hankycbr's Avatar
Thermo, thanks again you have been very helpful. I called the local Jag dealer and they quoted me $122 for the upstream sensor.
you mentioned $84 at Schucks/Advance/Kragens is that an OEM part? I never heard of that parts dealer? I live in the East Coast US. Can I buy an equivalent at Pepboys or AutoZone? or buy OEM at Jaguar? thanks again!
Old Aug 1, 2008 | 07:01 PM
Thermo's Avatar
Veteran: Navy
Hanky, that was for a Bosch part which is the OE part, just not with the Jag name on it. Autozone works too. Ask for a Bosch O2 sensor for your car. Chris "Thermo" Coleman
Old Aug 1, 2008 | 07:03 PM
Thermo's Avatar
Veteran: Navy
Schucks/Advance/Kragens is all the same store, depends on what part of the country you live in. Advanced Auto Parts is on the east coast. Also known at Checkers too. Chris "Thermo" Coleman
Old Aug 1, 2008 | 08:43 PM
hankycbr's Avatar
Thanks Thermo. I learn something all the time on this website.
Well Pepboys didn't carry an 02 sensor so I went to the local Jaguar dealer and they sold me the upstream o2 sensor for $107.00.
Question is, which of the 2 sensors upstream is the Bank 2?
thanks again in advance!
Old Aug 2, 2008 | 10:15 PM
hankycbr's Avatar
thanks Thermo!
here is an update: we replaced the bank 02 sensor and so far the check engine light went away.
Its nice not seeing that pesky check engine light!!!!!
Old Aug 11, 2008 | 07:37 PM
crashdata's Avatar
do you have the diagram on how to do this?
Old Aug 11, 2008 | 11:48 PM
hankycbr's Avatar
unfortunatelyI don't. my independent mechanic did it for me and he said it took about 2 hours since he had to remove alot of parts. Maybe somebody else may have one?
Old Aug 14, 2008 | 01:37 AM
crashdata's Avatar
I took my car to the mechanic today...all they did was change the lower and upper seal from the intake manifold...but the bad part they were missing one seal so they kept one ofthe old lower seal (is this good or bad?) nways the check engine light disappeared drove it around a bit.... lucky it was covered by my warr. wereas the 02 sensor was not.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
