check engine light on and sputtering!?!
Old May 16, 2008 | 02:40 PM
travis1215's Avatar
Default RE: check engine light on and sputtering!?!
what is the year and make that will help us lol
Old May 17, 2008 | 10:15 AM
FactoryJaguarTech's Avatar
For the p0171 & p0174 you likely need imt seals, breather hose and booster hose. The p0456 is an evap leak that could be coming from anywhere. Need to smoke test it to find for sure. The 02 sensor codes are probably because you had vacuum leak for so long related to the p0171/74 codes that you need 02 sensors. The seals and hoses your husband can definitly do. This may correct the 02 sensor problem. It may not.
Old May 24, 2008 | 07:48 AM
Thermo's Avatar
Veteran: Navy
moliz, when you are talking about O2 sensors and whether they are upstream or downstream, what they are refering to is the location of the sensor in relation to the catalytic converter (cat). The upstream sensor (also known as sensor 1) is between the engine and the cat. The downstream sensor (also known as sensor 2) is between the cat and the muffler. Both of these are important is the computer looks for a difference in O2 levels between the two sensors to ensure proper operation of the cat.
As a general rule, the downstream sensors don't fail as the conditions in which they operate are not that bad. The upstream sensors tend to fail if you are going to have an O2 sensor fail as they have to deal with the extreme temp of the exhaust and harse gases coming out of the engine. Replacing the upstream sensors now may not be a bad idea, but is not required. But, like some of the members say, "if it ain't broke, don't fix it".
If you need more info on this, just hollar.
Chris "Thermo" Coleman
Old Apr 19, 2009 | 11:26 AM
wjbell's Avatar
Hi - I'm having the same codes (P0171, P0174, P0133) from my 2002 X-Type, and the code reader includes the following measurements:
STFT Bank 1: 5.4%
LTFT Bank 1: 19.5%
STFT Bank 2: 3.9%
LTFT Bank 2: 19.5%
Fuel pressure: 5.4 Psig
Intake Man Press: 9.4 inHg
Mass Flow Sensor: .45 lb/min
Throttle Position: 3.1%
Do these help me in any way to define just where the vacuum leak might be? And do you know what STFT and LTFT are?
Thanks!
Jason
BrentGardner
29
Dec 16, 2024 12:13 AM
Bcrary3
Sep 3, 2015 10:36 PM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
