Climate Control Unit
Old Jun 20, 2018 | 06:10 PM
BudL1te's Avatar
Default Climate Control Unit
Hello,
The AC Light on the button of the Climate control unit started to flicker on and off for a week or so, I paid it no mind as the AC was still working properly.
Then the AC Just stopped working, blows hot air even with Auto selected or not.
AC Light does not come on.
Clutch does not engage at the compressor, It will not accept a Charge.
I have not checked fuse or relay yet but thinking about it wonder if it might not be a bad Climate Control Unit?
Any thoughts on that?
I will be checking the fuse and relay in a minute because always a first place to start.
I am also thinking about removing the connectors at the back of the CCU to ensure good connection.
Are the CCU's suspect? Is is common for them to fail?
Old Jun 21, 2018 | 06:36 AM
jaguarxjordan's Avatar
Since the clutch does not engage check the AC Freon 134a gas /
​​​refrigerant might be a leak .
Old Jun 21, 2018 | 03:57 PM
avern1's Avatar
The Climate Control Button activates the relay for the compressor. You can remove the relay and jumper the connection side to the compressor. If the A/C activates then the button has gone bad. You will probably have to replace the panel section as I don't believe the switches are separate parts.Try the jumper and let us know the results.
Old Jun 21, 2018 | 06:57 PM
BudL1te's Avatar
Thank you for your replies. I did some more investigating, found the fuse for the AC and it was burned. Tried another and burned straight away.
The clutch does spin but, and I will check again before finding a new compressor, it seemed to spin to easily. So I am concerned that the compressor is not well.
Since you cannot buy just the clutch for these I will have to buy a new compressor.
May still have issue with the CCU but at least I have a starting point.
Here is a good link for fuse identification: Jaguar X-Type Fuse Box Diagram » Fuse Diagram
Old Jun 22, 2018 | 07:47 AM
avern1's Avatar
Try removing the A/C relay and installing a new fuse. If it blows then there is a short between the fuse and relay connection. Next remove the fuse and swap the relay for the windshield washer to the A/C slot and reinstall the fuse.If it blows then the short is between the relay and the compressor clutch. Last thing check the condition of the wires around the compressor. They can get rubbed and chafe through.
jag_guy_2020
Aug 16, 2014 06:17 AM
JagX00
Feb 21, 2014 04:31 AM
Reverend Sam
Jan 16, 2014 09:38 PM
mystype04
Mar 22, 2012 12:52 PM
WinterJag
Jan 19, 2010 03:27 PM
