code reader issues
Old Aug 28, 2017 | 07:15 PM
reko19's Avatar
Default code reader issues
Was trying to use ELM327 (2005 X-type) that I successfully used on my other cars including XK8, the unit is totally dead and red led that is usually on as soon as I plug the reader in is dead. Is there a fuse I need to check, any suggestions?
thank you
Old Aug 28, 2017 | 08:20 PM
USarmor's Avatar
Reko19,
I could be wrong - but check fuses 72 and 80 . . .
Old Aug 28, 2017 | 09:07 PM
reko19's Avatar
Originally Posted by USarmor
Reko19,
only goes up to F56 according to the owners handbook...
Old Aug 29, 2017 | 06:13 AM
santer's Avatar
Check here
Jaguar X Type passenger bay fuse box
Old Aug 29, 2017 | 06:18 AM
USarmor's Avatar
I was just about to send you the exact same link that santer just did . . . it is in the passenger fuse box.
Old Aug 29, 2017 | 06:24 AM
USarmor's Avatar
On second thought . . It looks like the fuse box might have changed in 2005 or 2006.
According to one diagram I found, you may want to check fuses 7, 25, 32 if your fuse boxes only go to 56.
Old Aug 29, 2017 | 07:02 AM
reko19's Avatar
Thank you. Any idea where I could download electrical diagram for 2005? I don't think it is part of JTIS?
Old Aug 29, 2017 | 07:18 AM
reko19's Avatar
I think I found a download:
https://www.jaguarforums.com/forum/x...4-25-a-152076/
Old Aug 29, 2017 | 08:00 PM
reko19's Avatar
F25 was blown. Appreciate everyone's help. Will report back once i get a replacement.
Old Aug 31, 2017 | 06:12 PM
reko19's Avatar
F25 replaced, took care of the problem. I am only getting P1111 System Pass, so i guess everything is OK. Will wait till ABS light comes on again next time to get the codes.
thanks everyone
Old Sep 3, 2017 | 07:15 AM
JagV8's Avatar
You will need software that can read the ABS module. The elm327 can do it but that's (in effect) hardware.
Old Sep 3, 2017 | 07:18 AM
reko19's Avatar
Recommendations please. Anything available for iPhone or iPad? Thx
Old Sep 4, 2017 | 09:22 PM
Dell Gailey's Avatar
Android/IOS =
7 Best OBD2 (Android/IOS) apps For Your Car in 2017 | Archer Software
Old Sep 5, 2017 | 07:11 AM
reko19's Avatar
Based on the article, the only app that gives ABS info is Carista OBD2 which is only available for android.
Old Sep 9, 2017 | 05:39 AM
olca's Avatar
I have a XK8 MY2000 and had no problem connecting several OBD code readers to it: ELM328 (WiFi, connecting to DashCommand on my iPhone), Launch Creader VII+, Foxwell NT510 and Vgate ScanVS450. A few months ago they all worked. Now only the ELM328 works - the others say there is a communication failure.
Any ideas on what may have happened? I am particularly annoyed that the Launch Creader has stopped working, since it includes software for the ABS and the other systems that the generic ELM328 does not handle.
Old Sep 9, 2017 | 05:57 AM
olca's Avatar
Correction to my previous submission: It is an ELM327, not ELM328 that still works.
Old Sep 10, 2017 | 10:04 AM
reko19's Avatar
My ELM327 WiFi connects fine but I dont think it is capable to read ABS codes. I just bought iCarsoft i930 which connects to the ABS module. So far there are no codes and no indication lights, fingers crossed.
