Coolant Change
Old Oct 31, 2008 | 01:37 AM
Green Machine's Avatar
Default Coolant Change
Changed the coolant today. Only about 5 qts drained out maybe because the front end was only raised on ramps. I think I'll drive it for a few days then drain it again and raise the rear also so it's level. Maybethis will allow more to drain.
Somewhere I thought I read in a post about draining the cooling system that the shield under the radiator had to be removed but on mine there is a retangular hole under the drain that allows fluid to pass. Ofcourse a little did catch and spread along the shield but this happens on many cars an is no real problem. It would be nice if Jag would have used a better drain plug instead of the slotted plug.It does make the job a little messy.
I used 2 pair of needle nosed vise-grips to clamp off the heater hoses to do the burping and they worked ok.
Bob N
Old Oct 31, 2008 | 05:57 AM
racerx82's Avatar
Default RE: Coolant Change
Cool, nice job
Old Oct 31, 2008 | 09:52 AM
Dennis's Avatar
ud
DITTO Racer..Nice Job Bob..
I did mine also andI figure the remaining amount is in the block..So like you, I ran it for a few days, then drained it again...Recently had the water pump replaced (Warranty) and they had to use about a gallon of fresh stuff too..So I should be pretty clean as far as new Coolant..I hope you used Distilled water in your mix..I took a gallon to the dealer when they did my pump..and they were more than happy to mix the concentrate with the Distilled water I gave them..otherwise they told me they just use tap water...arrrrgg!
Old Nov 16, 2008 | 11:48 PM
Well I did my second coolant change today since I only got about 5 quarts of the old out the first time. This time I raised the rear of the car too leveling it. I would estimate about 6 or so quarts drained. I ran the engine also while it was draining at the beginning. So I guess I got all but a quart and a half or so this time.
Also I made a drain extention so the next time there won't be coolant where you don't want it, mainly all over the hands etc. I used a nylon plumbing threaded 1/4" x 1/8" barb fitting to screw in place of the original plug. Then I used a piece of 1/2" OD x 3/8" ID vynil tubing and at the end of this a brass winged drain plug. To protect this I afixed a pieced of metal to the plastic shield under the radiator drain.
Old Nov 17, 2008 | 05:58 AM
racerx82's Avatar
Once again, nice job!
Old Nov 17, 2008 | 09:03 AM
I guess I should mention that the threads on the barbed piece are US but very close to the 1.0 metric of the original drain plug. I guess because the nylon is flexible I was able to hand thread it into the drain hole after fastening the vynil hose on it with a screw clamp. I used some All Seal sealant on the barb since it is smaller than the inside diameter of the tubing I also used a clamp on the other end to secure the new drain plug. Oh, I put some sealant on the threads of the barbed piece too. I was able to use a short 5/8 open end wrench to further tighten the barbed piece inplace but I didn't go too much farther than the hand tightening because I didn't want to risk damaging the plastic radiator connection.
jimmiejag
Sep 9, 2015 02:56 PM
1100me
Sep 7, 2015 06:26 AM
Xkr x100
Sep 6, 2015 08:50 AM
Bcrary3
Sep 3, 2015 03:48 PM
