Coolant Tank
Old Jul 18, 2008 | 03:11 PM
Dennis's Avatar
ud
Default Coolant Tank
I just replaced my Coolant expansion tank..As I understand a lot of these had problems with the return line nipple cracking off as was this case...
Temporary Fix:
New tank;
Old Jul 18, 2008 | 03:13 PM
sbxt's Avatar
Default RE: Coolant Tank
I had that same exact problem on mine. It's amazing how much the dealer gets for that little plastic tank, isn't it?
Old Jul 18, 2008 | 03:21 PM
Dennis's Avatar
ud
Cleaned the engine too..
Old Jul 18, 2008 | 07:52 PM
jvegas's Avatar
wow! how did you clean it? what did you use?
Old Jul 18, 2008 | 08:42 PM
Dennis's Avatar
ud
I used regular Car soap/shampoo and used a lawn/garden sprayer to dispense it all over the engine...Then rinse well with hose and nozzle pressure...I then took off engine cover and Blow dried with Leaf blower and Compressed air and then let sun dry for an hour or two
Old Jul 18, 2008 | 08:44 PM
Dennis's Avatar
ud
Then I sprayed the entire engine/parts and hoses with this F21 stuff..Not greasy and it dries shiney..
Old Jul 18, 2008 | 09:51 PM
Dennis's Avatar
ud
ORIGINAL: sbxt
Yes, ridiculous
List: $192.21 What they would have charge if bought out right.
Net: $131.26 Means what theycharge if it's under waranty and they install.
jvegas's Avatar
is there anything i should cover up to keep water off of? and what is a "law sprayer"?
Old Jul 18, 2008 | 09:59 PM
Dennis's Avatar
ud
ORIGINAL: jvegas
LOL..Lawn Sprayer (ortho dial a sprayer)..Sorry about that..LOL
Good question..I cover the brake reservoir with a sandwitch baggieand avoid shoot water directly at the Altenator
Old Jul 19, 2008 | 12:37 AM
baguioboy's Avatar
Wow, I thought it was only my cat that little nipple broke, must be a common problem, I dont get it though, there is little pressure in that nipple why it breaks?
Old Jul 19, 2008 | 07:56 AM
sbxt's Avatar
It's a thinner plastic piece that, especially in areas that have cold winters, has temp changes from extreme cold to ultra hot... That would tend to make it brittle over time. Then, add in the flex of the motor that pulls on the hose and wiggles it... It's only a matter of time before it breaks. It's a poor design in my opinion.
Old Jul 19, 2008 | 03:54 PM
baguioboy's Avatar
Thats the best explanation so far, I can't agree more, a bad design. cost $150 bucks for replacement, I might just do some modification by adding a copper tubing to replace that plastic tank.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
vwbusbits
Oct 13, 2015 03:43 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
