Cooling Fan goes on/off Temperature goes up
Old Jul 12, 2009 | 01:39 PM
patrick12's Avatar
Default Cooling Fan goes on/off Temperature goes up
Hello,
when the engine is on the cooling fan goes round 10sec. on then 10sec. off and this repeat. Because of that EngineTemperature goes up.
What can it be?
Thanks, Patrick
Old Jul 12, 2009 | 02:02 PM
perezrp101's Avatar
Default have you checked your antifreez
check if you have coolant in your car if you do let me know then we will go from their
Old Jul 12, 2009 | 02:14 PM
patrick12's Avatar
for me is it the next hours not possible to check it.
Where is the difference when i have coolant or not?
Old Jul 12, 2009 | 11:46 PM
JagXType620's Avatar
I actually had the same problem. My cooling fan crapped out on me and thank god my car was under warranty and they repaired it. If I was idle in traffic you can see the temperature rise and AC getting hot. As soon as I started moving again, the temperature would drop, considering the airflow to the engine regardless of inoperable cooling fans. I would suggest you get this looked at ASAP and avoid any driving other than to the shop!
This is what jaguar wrote in my invoice:
Concern: "Customer states check engine light came on, temp gauge pegged and AC blowing hot, can hear fan turn on and off every 5-10 seconds while AC is turned on"
Correction/Tech Notes: "Verify check engine light is on. Cooling fans are inoperable. When temp got hot computer turned AC off. Test cooling fans. Replace faulty fans and verify proper operation OK."
Keep us posted! Make sure you don't do excessive driving because you can seriously damage your engine due to overheating.
Old Jul 13, 2009 | 02:35 AM
patrick12's Avatar
hmmm, today its fine it look at it repair itself, can it be?
Old Jul 13, 2009 | 08:24 AM
patrick12's Avatar
My Problem is comming again, the fan working 10sec and off then 10sec on, the air conditioner doesnt works.
Probably i need this part (cooling fan module) are the fan modules all the same for the x-type 2001-2007 ?:
Attached Thumbnails Cooling Fan goes on/off  Temperature goes up-a889_1.jpg
Old Jul 13, 2009 | 10:33 AM
Believe me, the problem didn't fix itself. If I was you I would take it to a shop ASAP. I'm not sure what part went wrong there can be a few things that happen, but you need to be careful in not blowing your engine due to overheating.
Old Jul 13, 2009 | 03:45 PM
patrick12's Avatar
i hope changing of the cooling fan module fix this problem. What are you think?
Old Jul 14, 2009 | 09:57 AM
Patrick, why don't you take it to a mechanic and have them suggest you what is wrong with it? And than you can go out and find the part for cheapest? That way you just don't replace things you're not sure is broken.
Old Jul 14, 2009 | 12:15 PM
patrick12's Avatar
of course i did it, jaguar machanics says its probably the fan module....but this people are not always in right
Old Jul 14, 2009 | 03:44 PM
True, so take it to another mechanic and see what they say.
Old Jul 14, 2009 | 04:23 PM
morales8416's Avatar
funny i got on today to post and ask about same problem.
Old Jul 14, 2009 | 05:27 PM
patrick12's Avatar
what you want do now?
Old Jul 15, 2009 | 09:40 AM
patrick12's Avatar
i cannot remove the one fan connector because this hose disturb.
I need to remove this hose or is there a another solution?
Old Jul 15, 2009 | 10:17 AM
going to change the same part
Old Jul 15, 2009 | 11:16 AM
whats the part number for the module? Apparently jaguar does not make the module anymore and modified the system so yoiu have to replace the fans also to put in the new fan system. so i found a salvage yard also and need to verify the part number.
thanks
Old Jul 15, 2009 | 03:04 PM
patrick12's Avatar
thanks
when you know this, please post it here.
Old Jul 20, 2009 | 02:03 PM
patrick12's Avatar
i hope i fixed my problem with a 70€ ebay used item. No problems after one Day drive.
X308XJR
May 20, 2019 06:50 PM
04Xjrsteve
May 7, 2019 04:06 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Darrenmb
Sep 27, 2015 08:43 AM
