Crazy Alarm!!
Hello all!
Could anyone help?
I have recently bought a 2002 X-Type LE (2.5L Auto)
On a few occasions I have had the alarm (without horn and indicators) sound when either locking or unlocking the car. I cannot understand why it sounds considering all doors, windows, boot and bonnet are shut correctly and no movement inside. (When this happens the alarm sounds for about 30 seconds then stops for about 5 seconds then sounds again at this pattern for about 5 minutes before turning off totally)
I'm operating the key fob as stated in the handbook but still at intermittent intervals the alarm sounds. (It has happened 3 times in 2 weeks)
The worst thing is that I cannot turn off the noise. I can unlock the car, put the key in the ignition, start the car, drive the car while the alarm still sounds.
Does anybody know why this happens and how I can turn off the noise?
Many thanks,
Ty
Could anyone help?
Many thanks,
Ty
No this is not it, I dug deeper though the forums and found it to be the passive alarm system (secondary alarm) which has been reported to sound when there's a drop in voltage or a low internal battery for the system. Although I'm not sure it's a battery issue as it only sounds when prompted by the locking/unlocking. I still can't find the resolution however..
I've had no obvious signs of battery trouble but I'll try to check.
Both my key fobs have caused the alarm to sound on seperate occasions however the fobs range seem weak and the buttons are 'mushy' ..perhaps it is a fob issue.
For a temporary fix I've removed the fuse for the battery back-up alarm/Air conditioner which so far has prevented the alarm sounding during the lock/unlock
hi one and all..........
i`m a newbie on here and i`m hoping i can find someone to help.
i am searching for a red leather sports interior and door cards for a 2002 jaguar x type, i have done the usual fleabay/ breakers ect, but no luck ?
is it because
1. they are not very popular ?
2. they were never made?
3. they are sought after and sell very quickly?
i cant seem to find any in the uk .
and finally, when they are available, how much do they usually sell for?
hope someone can help.
many thanks
gee
ps, sorry if i have put this in the incorrect heading/title/list.....
is it because
many thanks
gee
Both my key fobs have caused the alarm to sound on separate occasions however the fobs range seem weak and the buttons are 'mushy' ..perhaps it is a fob issue.
gee56, What do you mean by:'..red leather sports interior and door cards"i guess they are interior upholstery, If that you want, I don't think any body made them, if you want the seats you can try "Recaro" or any other OM sport car or after market, but they're not X-Type, or you can go to an upholstering shop and ask them to do a customer job, it will be expensive.
Update.
I managed to get access to the back up sounder by removing the inner wheel arch lining.
I disconnected the connecting plug which to my amazement was inundated with grease inside. Both the plug and socket had thick grease smothered around the pins.
I de-greased and cleaned both and reconnected. I'll see if that was the cause of the problem..
