Dash Vent: How To Take Off
Old Mar 5, 2008 | 01:47 PM
kmiecmonster's Avatar
Default Dash Vent: How To Take Off
How do you take the black vent, to the left of the steering wheel, off? It's rattiling like a ****. I want to take it off, put some felt around it so that it doesn't vibrate. Thoughts?
Old Mar 22, 2008 | 05:06 PM
Default bump
can i just pull it off?
Old Mar 22, 2008 | 05:25 PM
Cadillac's Avatar
Default RE: bump
Rattling vents are common problem on the X Types for the sake setting your mind at ease . Do a search on so that you sould find a solution . Otherwise try Technical Forums (not confuse w/ Forum Suggestions lol ) and post a thread on your problem .
Can you take it off ? You can but being a plastic it may be broken easily if you apply more than enough power hence you will need a set of vent . As I recall, glue can work for your vents but dunno for sure
Old Mar 22, 2008 | 06:03 PM
FactoryJaguarTech's Avatar
Default RE: bump
You pull the wood off around the instrument pack. It just pulls straight off toward you. Two phillps head screws hold in the vent.
Old Mar 22, 2008 | 07:25 PM
Dennis's Avatar
ud
Default RE: bump
Good to know how for future reference..thanks FJT
Old May 12, 2010 | 03:28 AM
cbrica's Avatar
I have the same behind the wood w/passenger_airbag or the vent next to it. Can someone advise how to dismantle those 2 pieces?
(i've tried and fixed the defrost vent and the pillar cover... we got too many rattles... or my hearing is too good )
Thank you!
R.
Old May 14, 2010 | 04:16 AM
cbrica's Avatar
I attach a picture to show what I want to dismantle.
Please help!
Thank you.
Attached Thumbnails  Dash Vent: How To Take Off-dashboard_570.jpg
Old May 14, 2010 | 03:01 PM
MarkC's Avatar
According to the pictures in JTIS, it looks like the woodgrain finish panel (over the airbag) just pulls straight out and is tethered to the dashboard. The right-hand vent is held in place with two screws that are visible when the finish panel is removed. Since the woodgrain finish panel blows off whenever the passenger-side airbag is deployed, I assume it should come off with some gentle prying.
Old May 17, 2010 | 06:05 AM
cbrica's Avatar
you mean it is not held in place on any side? wouldn't it hit the passengers face when the airbag deploys?
Old May 18, 2010 | 10:17 AM
cbrica's Avatar
I took them off.
I started with the piece arround the clocks + central vents. comes off much easier than the airbag part. they have different clips. it helped to take off the big piece first because then i was able to use some tools to pull the airbag piece out (the clips are much firmer not gentle ) pulling from the left side. it does not hit the passenger when airbag deploys because it has retaining belts and it is pushed on the dashboard. the vent comes of only by 2 screws.
Not solved the rattle but at least now I can fancy swapping the wood with carbon when I feel like a racer... provided that i buy the carbon trim in the mean time.
I suspect now the outside mirror. Little by little I shall learn to dismantle the whole X-Type :P
Poet
Oct 2, 2015 09:00 AM
Fletch44
Sep 28, 2015 02:21 PM
Long Islander
Sep 27, 2015 03:45 PM
the guardian
Sep 25, 2015 03:06 PM
