Do seats have to come out to remove C Pillars?
Old May 27, 2014 | 01:28 AM
4bizonly's Avatar
Default Do seats have to come out to remove C Pillars?
Do I have to take the back seats out to get to the screws to remove the C Pillars? I'm not sure where that screw is located and didn't want to pull out the back seats just to find out. lol My seats fold down and I read that there is a screw holding the C pillars in and if I try to pull them out they'll break unless I get to that screw. The A pillars pop out very simply, but I couldn't see where the screw is for the back C pillars.
Old May 27, 2014 | 03:02 AM
Cambo's Avatar
If you've got the fold down seat, then it's only the seat base and the side cushions that have to come out.
In order to get the C-pillars out you need to remove the parcel shelf, and in order to get the parcel shelf out you need to remove the side cushions, and to get the side cushions out you need to remove the seat base. LOL
Have a look in the Premium Sound Retrofit thread I did, I listed the part numbers of the plastic clips that you WILL break when removing the seat base. The side cushions also use those same clips, but you don't notice if they are broken...
Old Jun 4, 2014 | 10:24 AM
thegraytribe's Avatar
Default A Little more info
To remove the C-pillars. You do not need to remove the rear seat. Now be very careful with what I'm going to say. I have completely removed my rear shelf to install after market 6.5 Subs. There are only (4) components: 1) Rear Parcel Shelf, 2) Seat Belt Cover, 3) C-Pillar and 4) Seat Side Bolster
1. Pull the rear back rest down using the latches in the trunk (since yours fold)
2. Use you finger and push the tab/latch that is under the seat side bolster. THis will be hard to find so you may need to use a flashlight and pull the side bolster up a little. The fastener is about 3" from the top, it is white about 3in long. The clip fits into it and releases when you push this lever. YOU CAN NOT release the bolster without pushing this lever toward the side of the car (on the Driver side...on the passenger side you must pull the lever - go figure). So pulling very hard will only break the holder or the bolster!
3. Once the Side Seat Bolster comes down, you will see the screw that holds the C-pillar in place. THere are (2) a 10mm bolt and a push in plastic tap. The push screw must be carefully pryed out. Use plastic pry tool or flat head.
With these two loose c-pillar can come out. Simply pull from the top where the C-pillar engages with the Roof panel that comes down. THere is a plastic clip that disengages simply pull (a little force) and the C-pillar will come out and it slides out at the bottom.
With the C-pillar removed you have access to run wires to the trunk. I did this to install my Rear View Camera and SAT radio Ant.
Good Luck
Old Jun 4, 2014 | 06:14 PM
Default Pics to add
I didn't see how to add Pics in the edit mode, so I am adding a new reply
This pic shows the clip holding the Side Seat bolster down (Dr side). You must push the lever towards the door. Once the Bolster is released, you will see the (2) screws, one 10mm and one plastic that hold the C-Pillar and the SEat belt cover in place
This is the Seat belt cover that sits on top of the parcel shelf. This will come out when the screws are removed. From hear you can actually get wires into the trunk
Hope this helps
Old Jun 5, 2014 | 12:50 AM
Mr rx-7 tt's Avatar
Don't understand this. What is the "back rest"? Are you talking about the seat back or something else? Where are the latches located?
Pics?
Old Jun 5, 2014 | 08:15 AM
Default Rear Seat Back Rest
If your rear seat folds down to expose the trunk so that you can put long items in your Jag the latches are in the trunk. There are two and you pull them to release the backrest (Top of the seat were the headrests are located).
THis pic shows the back rest down looking into the trunk from inside the car. I don't have a picture of the pull latch in the trunk.
If your back seat rest is "fixed" then you will need to remove the bottom cushion and then remove the screws that mount the back rest to the frame to remove it.
Old Jun 5, 2014 | 01:12 PM
Mr rx-7 tt's Avatar
Mine are fixed so how do you remove the bottom cushion?
Old Jun 5, 2014 | 07:32 PM
Default Fixed Seats
Ok, since your rear seats are fixed you will need to remove the bottom cushion. To do that, you need to pull very hard on the (2) front corners of the bottom cushion. Start with the drivers side (open the rear driver door and stand over the bottom cushion putting your hands under the cushion close to the edge. Pull straight up (you may want to yank). It's not easy. There is a clip and white ring (like the one under the c-Pillar) THAT holds the seat down. Once you get that one, go to the passenger side.
Next push it up and then try to shake it loose from the back. You will need to get the seat belt latches out through the slits.
After you get the bottome cushion out you will see the bolts at the bottom that hold your back rest in place. remove them and push the back rest up to release it. THen follow the instructions above
Old Jun 5, 2014 | 09:19 PM
Mr rx-7 tt's Avatar
Thanks for taking the time to answer my questions.
dsnyder586
Dec 29, 2024 07:39 PM
Harry Dredge
Oct 4, 2024 05:37 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Clamdigger
Sep 12, 2015 03:43 PM
Dallas XK8
Sep 3, 2015 12:17 PM
