Doomed transfer case?
Old Feb 7, 2008 | 07:52 PM
Markus's Avatar
Default Doomed transfer case?
This, from the jag-lovers board, doesn't sound too good! FJT, is this your experience?
Some comments on the 'Air Scoop' used to aid cooling of the TC.
"These scoops are what the engineering world calls an '11th hour
patch' added at the last minute to help mitigate a high failure
rated part that became too late to fix the right way in the
development process.
The TC in the X-Type is woefully undersized and weak for a car of
this weight and engine size (and why engine modifications on this
car meant to produce more HP and torque will cause chronic failures
elsewhere in the drivetrain). Jaguar engineering was already in
field test, likely at the beta level when they discovered the TC
would be a problem, so they tacked on this air scoop to help rather
than reengineer correctly, but frankly, it is about the equivalent
of using a wine cork to stop a leak in the dike.
Engineering simply evaluated the cost of reengineering compared to
a clugy fix, and compared that to the estimated number of field
failures expected and concluded it was less expensive just to
replace TCs under warranty for a certain number of units. Of
course, now the car is old enough that many are off factory
warranty, and MANY TCs are succumbing on the owner's dime.
Because of the poor and late in the process design, these scoops
sit too low on the under chassis and are contiually ripped off in
deep snow and in encounters with other road obstructions. It is
much less a matter of lazy mechanics forgetting to relpace it after
oil changes. So, if you are going to replace yours, consider
purchasing a 'few' of them as inevitably you'll lose it more than
once if you drive regularly in deep snow or, god forbid, off road.
I agree, I'd rather have the scoop in place than missing, however,
failures of the TC are related to driving habits combined with
climatic operating conditions and condition of the oil inside the
case.
In other words, if you drive this car very sensibly in a colder
climate, with a fully filled TC and occasionally have to lock up
the VC, you might never experience a TC failure with or without the
scoop. However, if you're a leadfoot with a 3.0L and constant hard
accelerations driving in the very hot climate of Phoenix with a
half filled TC, even with the scoop, it's only a matter of short
time and you will be replacing the TC. "
________
1999 XJR
Old Feb 7, 2008 | 08:31 PM
jvegas's Avatar
Default RE: Doomed transfer case?
i dont get it. what is TC? sorry newbie question...
Old Feb 7, 2008 | 08:45 PM
Markus's Avatar
Transfer Case
________
1999 XJR
Old Feb 8, 2008 | 07:46 AM
RudyF6's Avatar
I've heard about this "scoop" before, would anybody happen to have a pic so I can see what I'd be looking for to see if mine's still there?
Old Feb 8, 2008 | 02:44 PM
Dennis's Avatar
ud
Ya know Bo,..Now that I changed my TC lube out to Royal Purple and you did the Red Line product (both top shelf lubes)...I believe, unless I was planning on keeping the car for another90K to 100K miles, I will not be changing it out again...We put in better than factory lubes and probably filled it to the proper level as well..
Old Feb 8, 2008 | 05:22 PM
jag_genius's Avatar
really helps to cool it. some times they brake off or people just throw them out.. im selling one to bo tonight you will see his soon
Old Feb 8, 2008 | 10:16 PM
Oldengineer's Avatar
ORIGINAL: RudyF6
I don't have a picture but - crouch down and look uder the front end of the car. Toward the back of the engine oil pan you'll see ahard plastic air scoop sticking down if its there. I've managed to knock off 2 of them.
Regards:
Oldengineer
ArtyH
Oct 2, 2015 11:39 AM
millertic
Sep 30, 2015 08:11 PM
Johnken
Sep 30, 2015 02:46 PM
dmatthewman
Sep 30, 2015 10:10 AM
