Driver side heated seat
Old Nov 9, 2010 | 02:24 PM
rjs852's Avatar
Default Driver side heated seat
Apparently my seat heater decided to stop working just as the weather is getting colder here in the east. I have checked the fuse and even went has far to swap out the passenger side heater control module..stil no heat. The switch light comes on but thats it.
Any ideas what to check next?
Old Nov 9, 2010 | 06:44 PM
TheSeeker's Avatar
Unfortunately, in my experience it has usually been the heating element itself that goes South on these.
Obviously, that's not a guarantee that your problem is the same.
If it's not the plug underneath the seat, the fuse and module don't make a difference, then it must be the element.
Old Nov 9, 2010 | 07:56 PM
rjs852's Avatar
Could it be the switch on the dash? As I said it does light up.
Old Nov 9, 2010 | 10:49 PM
LEB's Avatar
LEB
I have the same problem :/ Is it possible to switch the heating element in the passenger seat with the one on the drivers seat?
Still have to check the fuse and links and such but should take a sec when the sun comes up tomorrow. The switch light works as well...
Old Nov 10, 2010 | 09:10 AM
rjs852's Avatar
I believe the element is located in the seat cushion. Not an easy thing to access. I'm still hoping its the switch, I just don't know how to check it.
Old Nov 10, 2010 | 09:40 AM
TheSeeker's Avatar
If you have a multimeter, set it to the Ohms setting. Then clip the two leads terminals. When the switch is on, you should have continuity (the needle moves up). When the switch is off, you should have no movement.
If the multimeter needle never moves no matter what the switch position is, then the switch is dead.
You could also do this procedure at the plug end under the seat but since the power will be on (battery connected and ignition key on) just check to see it you get voltage (do not use the Ohms setting).
Old Nov 10, 2010 | 10:49 AM
rjs852's Avatar
Thanks Seeker, but could you be more specific?
Were do I connect the leads to under the seat?
What should the voltage read?
Old Nov 10, 2010 | 11:55 AM
sidewalkman's Avatar
Should be a couple of plugs under the seat, one for the power seat motor, and another for the heated seat. Not sure but on my BMW there was a 3rd plug for the airbag sensor.
Old Nov 10, 2010 | 02:42 PM
TheSeeker's Avatar
As sidewalkman said, there will be several plugs underneath the seat. Unplugging them one at a time and seeing what stops working will narrow that down.
The actual voltage won't really matter (I suspect it should be 12V though). You are testing to see if the switch is allowing power to the plug. If you show power (voltage) there at the plug, then you know that everything is OK to that point and it would leave only the heater element as the source of the problem.
Old Nov 10, 2010 | 07:22 PM
rjs852's Avatar
Well I've checked the voltage at the control module and I'm definatly getting power to that point. I guess the only thing left is a loose wire/plug or the seat element.
Has anyone replaced a seat element?
Old Nov 10, 2010 | 09:12 PM
TheSeeker's Avatar
I did one on a Volvo I used to own and I wouldn't care to do it ever again! The seat has to come out, then you have to "un-upholster" the seat to gain access to the inner seat padding. From there it's pretty obvious and straightforward as to how to replace it.
You really do need to check if there's power as close to the seat element as you can possibly get. That will at least eliminate any possibility of it being a plug or wire problem.
Old Nov 10, 2010 | 11:59 PM
Tec Nine's Avatar
multimeter will do the job
mbergen
Oct 23, 2019 10:26 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Dicque
Sep 19, 2015 12:53 PM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
