EGR Valve
Old Apr 29, 2015 | 08:52 AM
voltage39's Avatar
Default EGR Valve
Hi,
I need a picture where my EGR Valve is on my 2002 Jaguar X. Thanks in Advanced.
Old Apr 29, 2015 | 10:37 AM
dwclapp's Avatar
Sharree: Do you have a diesel or gasoline X-Type? I ask because I believe Jaguar used EGR's only on 2.0 & 2.2L diesel engines more common in European X-Types, and not on 2.5L and 3.0L gasoline engines more common in U.S. X-Types.
Here's a diagram of the EGR system on an X-Type diesel engine:
FYI, EGR's were previously used on gasoline engines to reduce NOx emissions, but I understand this is now accomplished via computer controlled IMT valves & fuel injection on our gasoline X-Types.
Why do you ask about EGR valves?
Old Apr 29, 2015 | 04:31 PM
voltage39's Avatar
Thanks for the response! My Check Engine light came on, so I ran a check on it and the code came up it says p0400 code. my car is gasoline. X type, not sure if it is us or European. It misses when you first start it up just like it says it does when the EGR Valve is bad or clogged.
Old Apr 29, 2015 | 07:18 PM
dwclapp's Avatar
Voltage: This is odd. The workshop manual does not list a P0400 error code, not even for 2.0L and 2.2L diesel X-Types which have EGR valves. And X-Types with gasoline 2.5L and 3.0L engines don't have EGR valves, according to the manual.
Can you double-check the error code(s)?
Old May 19, 2015 | 05:16 PM
voltage39's Avatar
Default Wrong code
Thanks Dwclapp, I finally got a chance to run the scan code again and I did write down the wrong code.....It is p0430. Thanks again for the advice.....
Old May 21, 2015 | 03:21 PM
dwclapp's Avatar
Voltage: The threads below discuss the P0430 error code and multiple ways people addressed it. I'd pay particular attention to suggestions by Itmax in the first thread. His X-Type mechanical restoration is amazing - see the last thread.
Hopefully you can clear your P0430 code by replacing an oxygen sensor, or running a can of Cataclean thru the gas tank, and don't have to replace a bad catalytic converter:
https://www.jaguarforums.com/forum/x...ing-me-113796/
https://www.jaguarforums.com/forum/x...nverter-46696/
Cataclean | Cataclean Liquid Science | Cataclean reduces emissions
https://www.jaguarforums.com/forum/x...mplete-116656/
Good luck.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
