Engine Code Problems...
Old Oct 24, 2008 | 04:32 PM
mohrd's Avatar
Default RE: Engine Code Problems...
Looks like you'll be able to figure the lean both banks codes.
Can't help much with the P1796. Possible Trans Control Module failure?
Old Oct 24, 2008 | 06:05 PM
mohrd's Avatar
here they be...thanks Dennis...passenger side
Old Oct 25, 2008 | 02:34 AM
BuckMR2's Avatar
Had simialr problems with my 02 3.0 Sport.
Both banks running lean caused by air leak.Eventually found to be this pipe which tooka minute to replace:-
Jag dealer said sell lots of these and with your car being a similar age yours maybe at fault too, as the factory fit ones are thin and tend to split.
The replacement pipes cost around GB£5 and are much much sturdier due to being redesigned to not deteriorate as quickly.
Let us know how you get on.
Old Oct 26, 2008 | 03:21 PM
racerx82's Avatar
If you need an IMT, i have one. PM if interested. Only had 10K miles on it.
Old Oct 31, 2008 | 10:47 PM
mohrd's Avatar
Default RE: Engine Code Problems...Update
The problem is most likely gone but the code is still stored until it's been cleared?
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
