Fan runs all the time. replaced control module, high only. turns off. battery drains
Old Dec 20, 2019 | 04:08 PM
JimbojJumbo's Avatar
Default Fan runs all the time. replaced control module, high only. turns off. battery drains
2002 X-Type radiator cooling fan runs all the time, even when engine shuts off. Replaced control module, Now fan operates on high only, but turns off when engine shut off. Also, now battery drains until dead.
Any help ur suggesteions would be appreciated.
Old Dec 20, 2019 | 04:48 PM
Alfadude's Avatar
Are you low on coolant? That could account why the fans run when the car is running. Has the car overheated at all?
Will your car start now or when you say the "battery drains until dead" do you mean now nothing happens when you try and turn the key to start the car?
How old is your battery?
Old Dec 20, 2019 | 05:46 PM
Dell Gailey's Avatar
Did you replace the fan control module with one of the Asian internet ones?
Old Dec 21, 2019 | 11:22 AM
DUNKS's Avatar
I suffered this problem. Turned out to be a faulty engine temp sensor.
Old Dec 23, 2019 | 11:58 AM
Fan runs on high all the time engine is running. now battery drains when shut off. Negative wire hot.
Old Dec 23, 2019 | 12:00 PM
Battery relatively new. Tested and OK.
Not low on coolant.
Battery drains while engine is turned off. Negative wire hot to the touch.
Purchased on Amazon.
Old Dec 23, 2019 | 01:54 PM
That's your problem. The amazon Asian fan controllers don't work correctly.
https://www.jaguarforums.com/forum/x...models-222569/
Old Dec 24, 2019 | 02:25 PM
Thanks for the info. I hope that solves the problem. Will let you know!
Krasi
Aug 11, 2019 03:48 PM
Madatacksboom
Dec 28, 2018 10:42 PM
marlind backa
Oct 6, 2018 04:02 PM
nj-jag
Jul 18, 2018 04:25 PM
BALTVISTA
Nov 2, 2017 10:38 PM
