Front wheel bearing???
Old Jan 16, 2019 | 04:31 PM
DUNKS's Avatar
Default Front wheel bearing???
Perhaps I am daft asking but what ho. I have thought for a while I perhaps have a front nearside" UK" wheel bearing going. Its a ying ying ying noise at road wheel speed, You have to listen carefully it's not loud. No vibration and is more pronounced on a good road surface. BUT my garage suggested it could be a tyre. It's not I have had the fronts swapped to the back. Noise is still the same
Problem is I have had wheel bearings go before and always the noise alters when you lean hard into a bend either way. This does not it's constant.
I can of course have the bearing done, cost is not too bad, but I still have a feeling in my water it might be something else.
Any bright suggestions please.
Old Jan 17, 2019 | 01:33 PM
Dell Gailey's Avatar
Stuck brake pad? Other than that, I'd lean towards bearing. The ying, ying, ying is a rotation squeak/squeal to me.
Old Jan 17, 2019 | 01:46 PM
DUNKS's Avatar
Default BEARING
Thanks. No it's not a brake pad. Also it's not a squeal. I think perhaps it is the very first indication of a bearing that's on the way out. i do hope so as it's an easy fix.
Old Jan 17, 2019 | 02:07 PM
NBCat's Avatar
Have the garage check the speed sensor and pulse ring on the nearside outer end of the drive axle. They sometimes can have something caught in the splines that can cause that type of sound.
The best way to diagnose such a sound is to have the vehicle raised and the engine running. Place the vehicle in gear and get up to the speed you hear the noise. Use a stethoscope, or a long screw driver, to listen to stationary parts to see if the noise it transmitted and to isolate the source.
If the noise is not present, it's most likely a tyre.
Old Jan 17, 2019 | 02:23 PM
DUNKS's Avatar
Thanks it's not a tyre. Read my OP. Also a visual has been done when it had it's MOT.
Sorry but my garage does not have the facility to safely run the engine on a raised lift.
Old Jan 17, 2019 | 02:44 PM
NBCat's Avatar
Yes, I did indeed read your original post, thus did I suggest raising the vehicle to eliminate all four tyres from possibly being the source. A visual inspection during MoT is not going to identify a tyre having an internal casing issue.
Find another garage.
Old Jan 17, 2019 | 02:58 PM
DUNKS's Avatar
I am so very sorry if I have confused you.
The visual check was done at the same time as the MOT. Guy is a friend. Both front wheels were removed for the inspection of the disc pads and any foreign matter. Front wheels were then swapped for the rears. The noise is obviously from the front nearside, confirmed by drivers and passengers. Tyre swap has not altered noise so not tyres.
If you are going to be real pedantic the work was not done during the MOT "not allowed", but after it.
Thanks anyway any input is helpful.
Old Feb 5, 2019 | 01:33 PM
DUNKS's Avatar
Default NOISE
OK folks. had a service. New brake pads all round. AND A NEW FRONT NEARSIDE BEARING.
Sound is till the same so it was not that. Running out of options now. Looks as if I must wait for it to get worse. Whatever it is!
Old Feb 5, 2019 | 01:46 PM
dennis black's Avatar
are your rotors warped ,if not it could be the other side bearing
Old Feb 5, 2019 | 02:16 PM
DUNKS's Avatar
Rotors "discs" as we call them are fine. Could of course be the other bearing but cant see how the noise transmits to nearside. I have asked several passengers and all say the same. Two drivers too have insisted it;s nearside.
Thanks for the thoughts!
kain3488
Dec 14, 2018 01:58 PM
psiharath1
Sep 27, 2013 02:53 PM
rdcsat
Nov 16, 2007 06:20 PM
bojangles
Jan 29, 2007 08:20 PM
