full official maintenance schedule for 2004 X type
Old Jun 17, 2013 | 11:11 AM
ausfalcon's Avatar
Default full official maintenance schedule for 2004 X type
What is the full official maintenance schedule for a 2004 X type (2.5 manual)?
I found this image online but it refers to 2001 and 2002 model years:
http://i15.photobucket.com/albums/a3...tp926_0001.jpg
My car has 98,5xx miles on it so I want to make sure if anything like a timing belt/chain needs to be checked etc that I get it taken care of.
Old Jun 18, 2013 | 04:29 PM
astromorg's Avatar
The only change from the document you have for MY2004 is that the mileages for the drive belts goes out from 100,000 to 150,000.
There is no camshaft drive belt to change and no suggestion about servicing the chain drive. (I can't recall anyone ever having a problem with them, even at much greater mileages than yours)
Nor does Jaguar give any guidance on changing oils in the gearbox, transfer box or rear differential, but you might want to consider those!
Old Jun 18, 2013 | 07:54 PM
oldpunk's Avatar
If it helps, I bought my 04 about two months ago with 85k on it and here is what I've done so far:
Changed MTX transmission fluid
Changed transfer case fluid
Changed rear diff fluid
Changed coolant reservoir (only because mine was leaking)
Things I plan to do in the next few weeks:
Change air filter
Change cabin filter
Change spark plugs as soon as I figure out how
Find out if mine has a PCV valve and if so change it
Find out how easy/difficult to change the fuel filter
All of these are basic things you should do after buying any used car.
Old Jun 19, 2013 | 08:15 AM
pab's Avatar
pab
>Nor does Jaguar give any guidance on changing oils...
Ya, the regular scheduled maintenance is pretty brief, oil/filter, spark plugs, drive belt, filters, inspection of other things, that's about it from Jaguar's standpoint. But, I always considered the fact that the engine has a cam-chain rather than a belt to be a pretty big plus with these cars!
Jaguar - it's not an automobile, it's a Motorcar
Old Jun 19, 2013 | 08:24 AM
https://www.jaguarforums.com/forum/x...-diesel-67611/
Old Jun 19, 2013 | 09:19 AM
ausfalcon's Avatar
Thanks guys. Yeah a timing chain instead of a belt sounds like an extra bonus to choosing this car.
Old Sep 12, 2013 | 07:27 PM
chiefshb's Avatar
Change air filter
Change cabin filter
Hey Oldpunk...not sure if you've figured any of this out yet but here is a link for replacing spark plugs. I used it to remove the intake manifold so I could change my low level A/C line.
https://www.jaguarforums.com/forum/x...nge-faq-48128/
There is a PCV valve. Open the hood and look down. There should be a ribbed hose running from the intake manifold to the PCV valve. Sorry for the cut off pic, but I was looking at something else. the valve is where the arrow is pointing. Replacing it tomorrow on my '04 X.
The fuel filter was changed for me during an oil change (was in a hurry and had to have someone else do it), so I can't help with that one.
Like I said, sorry for the redundancy if you already figured this out, but thought I'd put it up just in case.
Attached Thumbnails full official maintenance schedule for 2004 X type-img_1337.jpg
Old Sep 12, 2013 | 07:51 PM
silkcat's Avatar
They recommend removing wipers to do the cabin filter but it's possible to sneak it in and out by simply lifting up the cowl after removing the plastic pins. Fuel filter on my 2004 is just in front of the passenger rear tire. Easy to reach and change out. No special tools needed as it has plastic pins securing each end of the filter.
Old Sep 12, 2013 | 09:29 PM
chiefshb's Avatar
No need to remove wipers. I just did this not too long ago and all I did was remove the clips and pulled the cowling away from the passenger side. Filter pulled right out and went back in with no issues.
Old Sep 12, 2013 | 10:08 PM
chiefshb's Avatar
What part of The Lou you from Silkcat? Grew up in Overland before life took hold and had to move around. If St. Louis had Florida weather, I'd be back in a heartbeat to stay. Until then, it's just to visit family. Go Cards!!!
Old Sep 13, 2013 | 02:16 PM
silkcat's Avatar
Chiefshb - grew up in south city, now live in south county near telegraph and I255. Know what you mean about the weather. Wife and I escape to Florida most every January.
stanjag
Dec 29, 2024 08:26 PM
DrScientist
Dec 9, 2015 07:36 PM
Aranon
Sep 1, 2015 01:00 PM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
