gearbox fault engine systems fault / engine revving
Old Mar 25, 2012 | 02:00 PM
afonda's Avatar
Default gearbox fault engine systems fault / engine revving
cant figure this out.
Engine system fault / gearbox fault lights coming on and the engine is revving. This happens after the brake pedal is depressed. Then the engine starts to rev up but the car hesitates.
Also having another issue.. The back up sensors are causing the amber dash light to come on and the sensors are no longer working properly. This only happens when in reverse obviously. Also, causing the rear lights to malfunction and not illuminate as they should almost like the wires are crossed.
Old Jul 24, 2012 | 10:17 PM
gridster72's Avatar
Default engine sys and gearbox fault. engine reving
i never seen any reply to afonda mess i have the same prob. what is it?
Old Jan 26, 2013 | 12:22 AM
TheCousinDan's Avatar
Check the wires at the connector for the throttle position sensor. It's completely unreasonable how the computer reacts to such a seemingly small issue, but it was 100% the issue that solved the exact same symptoms. One wire was loose.
Old Jan 26, 2013 | 08:09 AM
Jeeves12's Avatar
I had the exact same problem 2 weeks ago. The yellow wire on the throttle body plug came loose.
The yellow wire pulled out while I was working on the manifold over two years ago. I reclipped the wire, pushed it in the plug harness and then filled it with silicone. However, driving on the wonderful roads of Chicago with all the potholes must have backed the wire off.
If those wires are all OK, check the brake sensor. You stated it only starts after you press the brake pedal. Does your "brake" light, lower right on the dash - red, come on?
Old Jan 27, 2013 | 10:06 AM
It was the yellow wire for me too. I'm assuming there is an ergonomic issue with how that wire is physically pulled and tugged on when you remove the intake elbo. My suggestion is to unplug it before removing the and rolling the elbo out of the way.
Old Jan 27, 2013 | 04:13 PM
yvonnetorres's Avatar
Throttle Position (TP) Sensor 18.30.17
Removal
Vehicles with 2.5L or 3.0L engine
  1. For additional information, refer to Throttle Body.
Vehicles with 2.0L engine
  1. Disconnect the battery.
  1. NOTE: 2.5L and 3.0L shown, 2.0L similar.
Remove the engine cover.
Disconnect the air cleaner outlet pipe.
  1. Disconnect the electrical connector.
  1. Remove the the throttle position (TP) sensor.
Installation
  1. To install, reverse the removal procedure.
  1. Tighten to 7 Nm.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
