Gearbox Fault message.....
Old Apr 18, 2021 | 09:36 AM
jrdelohery's Avatar
Default Gearbox Fault message.....
2005 Type X Estate 121k: at 70mph vehicle suddenly entered a lower gear (higher rpm) with Gearbox Fault message displayed, furthermore there "has been some kick" during acceleration. Appreciate any lessons learned. Thanks...
Old Apr 18, 2021 | 11:11 PM
Thermo's Avatar
Veteran: Navy
jrdelohery, I would say to start with pulling any codes that the OBD port has. You should have a code since the car is saying that it has a gearbox fault. That will help narrow things down significantly. Post the code here and we can take things from there. From the sounds of things, I would venture to guess that the wiring to your solenoids has found a hot spot and now one of the solenoids is grounding out, causing issues with the TCM (hence the gear change, the car defaulted to fourth gear).
Old Apr 24, 2021 | 06:49 PM
jrdelohery's Avatar
Not certain code P1111 means. Appreciate any next step thoughts. jrd
Old Apr 24, 2021 | 08:15 PM
Dell Gailey's Avatar
P1111 means all tests performed and passed
Old Apr 24, 2021 | 08:52 PM
motorcarman's Avatar
The DTC is likely stored in the TCM and not in the ECM.
P1111 means the ENGINE is happy but what about the gearbox?
Old May 13, 2021 | 12:20 PM
jrdelohery's Avatar
Default Gearbox Default 2005 X Estate 121m
I
Last edited by jrdelohery; May 14, 2021 at 11:48 AM. Reason: Not certain how to proceed.....
Old May 19, 2021 | 08:42 PM
jrdelohery's Avatar
Finally code PO778. Appreciate any comment. Thank you!
Old May 19, 2021 | 08:51 PM
jrdelohery's Avatar
Thank you so much for your input Thermo! PO778 was pulled.
Old May 19, 2021 | 11:02 PM
https://www.jaguarforums.com/forum/x...-p0778-147745/
enderle
I-Pace EV
Sep 22, 2020 03:40 PM
frustratejagowner
Mar 7, 2014 02:49 PM
MikeStevens
22
Mar 14, 2011 03:04 AM
ckmk925
Jul 29, 2008 05:30 PM
