gearbox help
Old May 11, 2013 | 03:01 AM
Aaronhannemann's Avatar
Default gearbox help
I have a 2003 2.5 auto
When i shift from drive to 4th the gearbox light comes on..if i turn it off and on then drive around 10 minutes it will go away
Old May 11, 2013 | 03:41 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'.
Old May 11, 2013 | 04:33 AM
Jagman68's Avatar
Hi,
Your problem is your cable needs to be reset, I had this with my car its reasonably easy to do.
Good luck
Old May 11, 2013 | 02:44 PM
That did not solve it..i took my -off 20 minutes then started it then put it into 2 and tried to drive and the yellow gearbox fault comes up..the automatic works fine but anytime i shift over to 2,3,4 this will happen and ill get shifting issues untill it resets
Old May 12, 2013 | 10:14 AM
Could somebody help diagnose i havnt seen this on this forum...or send me to the proper thread
Old May 13, 2013 | 07:35 AM
Jagman68's Avatar
Hello,
I did send you a proper thread hope you would have had more luck sorry please click or copy and paste into browser.
http://www.jagrepair.com/images/TSB/...n%20Ranges.pdf
Good luck
Old May 13, 2013 | 01:33 PM
Thanks jagman the thread showed up this time...this should work once i actually understand it
Old May 13, 2013 | 10:39 PM
On step A it states to turn ignition off then put it into nuetral...when i try that it starts beeping..
Old May 14, 2013 | 02:26 AM
If it's the same as an XK it will shut up after a bit!
Old May 14, 2013 | 05:03 AM
Jagman68's Avatar
Yeah it's just the warning beeb to let you know it's not in neutral it's nothing to worry about.
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
jjmiah217
Sep 28, 2015 09:09 AM
drbill
Sep 28, 2015 12:46 AM
