Help with double din
Old Jan 11, 2013 | 10:00 AM
Gizzer23's Avatar
Talking Help with double din
Can anyone help have tried installing a media double din but behind the system is a what I think is a air con pipe . This make the system stand out bout about an inch . Has any one had this problem and solved it ??
Any help would be great
Old Jan 11, 2013 | 12:11 PM
Repkim's Avatar
Default 2-din
Did some research about this earlier. One of the models that has fitted properly is Pioneer AVH-P4100DV which is discontinued product.
Dimensions (W × H × D):
DIN
Chassis ..................... 178 mm × 100 mm × 165
mm
(7 in. × 3-7/8 in. × 6-1/2 in.)
Nose ........................... 171 mm × 97 mm × 9 mm
(6-3/4 in.× 3-7/8 in.× 3/8 in.)
I guess these are the general guidelines by what you have to choose the head unit by.
Hope you can change your head unit to something that fits.
Old Jan 11, 2013 | 12:19 PM
pab's Avatar
pab
Houston we have a problem
Crutchfield offers no in dash audio systems for our cars...
Jaguar - it's not an automobile, it's a Motorcar
Old Jan 11, 2013 | 12:23 PM
Repkim's Avatar
Default useful thread
https://www.jaguarforums.com/forum/a...e__ouch-32701/
Old Jan 11, 2013 | 02:24 PM
Gizzer23's Avatar
Talking Thanks
Thanks for that . That does help . I wonder could any one explain to spacers? Are they used so that the unit can sit further back in the cage ? And does any one know where I can buy these because I can't find them online ?
Old Jan 14, 2013 | 10:02 AM
Aamir's Avatar
I recently installed Pioneer AVH 3300BT, also stuck out a inch or so, but this was purely because of the chunky heat sink. So I kindly introduced it to mr hacksaw......
Nip, tuck, done.........
Old Jan 15, 2013 | 05:40 AM
Gizzer23's Avatar
[QUOTE=Aamir;656486]I I didn't think you could cut the heating bit ?? U was told Would ruin heating in car ? Have you got any pics to show at all ??
Old Jan 15, 2013 | 05:47 AM
Aamir's Avatar
[QUOTE=Gizzer23;657085]
Let me clarify...
There was a large aluminium heat sink on the back of the Pioneer unit, I trimmed it down to about 50% of it's original size, now the unit sits flush
I did not modify the cars heating system/ducts
Old Jan 15, 2013 | 07:35 AM
Gizzer23's Avatar
Thumbs down
Ok mate that makes sense I would I could do that with the unit I bought but I don't think I can guess will have to have it sticking out
Old Jan 15, 2013 | 08:47 AM
Repkim's Avatar
Default Shape not size..
Ok, what it comes down to, is that even 157mm deep unit doesn´t fit properly if the unit has some bulk in the top.
Standard 165mm deep units should also fit if the depth is less in the top of unit.. Have to do some research into this.
I wouldn´t feel to comfy about reduding the size of the heat sink to half of original. I´m sure that Pioneer has done some calculations for things like this. Quarantee's gone also..
Old Jan 16, 2013 | 05:25 PM
dennis black's Avatar
if your deck have these dimensions it will fit
pops right in
connector for steering wheel controls
Attached Thumbnails Help with double din-deckz1-1.jpg   Help with double din-x-deck001.jpg   Help with double din-steeringadapter.jpg   Help with double din-kenwoodbezel.jpg   Help with double din-010-3.jpg
here you go
oldjaglover
Dec 25, 2024 04:33 PM
LnrB
Oct 13, 2015 12:45 AM
muntasarz
Sep 29, 2015 08:20 PM
Chris Hinton
Sep 24, 2015 08:38 PM
