HELP !!!!! S.O.S !!!! locked my key in the trunk
Old Mar 23, 2016 | 07:57 AM
8pockets8's Avatar
Default HELP !!!!! S.O.S !!!! locked my key in the trunk
Help. Got to. Work this morning and locked my key in the trunk.
Is there anyway to unlock the truck from inside the car? Or anyway to
Flip down the back seat from inside the car?
So screwed only key I have. Please help
2004 jag xtype 2.5 manual
Old Mar 24, 2016 | 05:21 AM
8pockets8's Avatar
ok cost me $65 for a lockshop to come out and program a new fob and open my boot. then he had to reprogram my original key.....
Old Mar 24, 2016 | 05:30 AM
chiefM's Avatar
Sorry about your troubles, I really need to get another key and FOB.
Old Mar 24, 2016 | 11:44 AM
8pockets8's Avatar
Yeah same here. He cut and gave me a emergency key. But all that will do is unlock the doors for me if I lock the keys inside or something. Won't start the car.
But
ood to have until I can get a true spare. Have to find a good ebey dealer and buy a blank and my locksmith said he would cut and program for $75 if I bring him a blank.
Other wise from him it would be close to $300
Old Mar 24, 2016 | 11:48 AM
Alfadude's Avatar
You mean your car doesn't have the electronic button above the license plate area? I thought all US cars came with that?
Old Mar 24, 2016 | 12:05 PM
zzr600's Avatar
I did this in my x type I used a coat hanger to open the drivers door then had to remove back seat then reach through into trunk area to retrieve the keys.
Old Mar 24, 2016 | 07:08 PM
8pockets8's Avatar
i do. but unfortunately we couldnt get it to unlock for its use. they said that when you put the key in the door and turn it that the boot should unlock along with the doors but it wasnt
said that there must be a malfunction somewhere. i told him i didnt know. since ive owned the car the only way i know how to open the "boot" is off the key fob.
yeah theres that little button there but once you close the trunk its locked up tight heh
thought about trying to fish through the back seat and snag the release on the seat somehow.
but after a long day of work my local locksmith was just the easiest solution
Old Mar 24, 2016 | 11:05 PM
wa3ra's Avatar
The problem with going through the back seat is that the release knob goes towards the BACK of the car, and it is at a difficult angle with regards to where you can get a tool in.
Best bet is removing the lower seat, then using a long tool to reach and pull the escape handle down. Great in the States, but the vars don't have that handle in most other countries.
Old Mar 25, 2016 | 05:00 AM
henry k's Avatar
I do not have any problems when / if I lock my keys in the trunk (boot).
A simple modification costing little to obtain a
http://www.electricalwholesaler365.c...s/GT610HDB.jpg
I have since done a small modification costing "shirt buttons" to make things even easier.
Finally I have a simple modified flat key blank that is used as a screwdriver similar to this
http://www.walkerlocksmiths.co.uk/im...55-700x700.jpg
No 1 rule. Immediately on owning an X Type is
ENSURE YOU HAVE TWO PROPER, FULLY FUNCTIONING KEYS.
That will as a minimum open the door and will start the engine
I would also ensure you have the key cutting code for you key ( known as a TIBBE key).
It will be in the form of T423141.
Hint. Look it up on the web. It is easy to read your key code.
UK independant companies will supply cut keys from just seeing a photo.
A basic Ford style key without buttons will fit an X Type.
Old Mar 25, 2016 | 07:39 AM
flyrr100's Avatar
All X Type owners. Do this quick fix.
You need to take off the yellow quick release handle the all US cars have. I know they are to save your kids if they get locked in, but if that happens blame Darwin! (kidding)
Remove the plastic cover. It's a few screws. Thread a plastic tie from the point the handle was at, through one of the holes behind your tag. When you remove the cover it's easy to figure out. Make sure it can't be seen. So now when you lock anything in your trunk you just remove or bend up your tag and pull the tie. And your boot/trunk will open. Do it now, because there are those who have, and those who will lock their keys in the trunk, or have the electronic button fail.
The plastic cover
What the tie should look like
Old Mar 25, 2016 | 08:44 AM
DPK's Avatar
DPK
good advice!
Old Mar 25, 2016 | 09:03 AM
iownme's Avatar
Originally Posted by DPK
good advice!
A cheap way to get in is to break the rear light lens, a used lens is super cheap on ebay, less than a locksmith. Good to know in a real emergency
vice guy
Nov 28, 2016 08:31 AM
jackra_1
Mar 8, 2016 04:10 PM
r__h
Mar 5, 2016 03:12 PM
redxk8
Mar 4, 2016 08:32 AM
Atlantamark
Mar 1, 2016 10:19 AM
