hesitation low rpm, high torque load
Old Jan 9, 2009 | 02:08 AM
pilot76s's Avatar
Default hesitation low rpm, high torque load
My old man special ordered his x-type from england. 5 speed stick,3.0 motor with all the bells and whistles. It has everything except the sport package.He never was the kind to take it in for service soi have been doing all thework to it. 3000 mile oil changes, air filter, spark plugs, fuel filter...the basics.Its 100% stock. 150,000 miles (all highway)
Anyway, under normal driving it is a perfect jag all through the rpms. Once you open the taps, at low rpm it doesnt like it.at around 2800 it begins to smooth out but at 3000 the headlights dim and you can feel the smallest of studders. The hesitation at low rpm feels as though it isonly running on half the motor. Any suggestions on where to start? I'm leaning towards an electrical problem starting at the battery or alternatorsince the headlights dim. Any help at all would be greatly appreciated. Thanks
This is the first majorproblem we have had with it -- EVER! Great car Jaguar!
- The New Guy
Old Jan 9, 2009 | 05:37 AM
JagXV6's Avatar
Default RE: hesitation low rpm, high torque load
Could be an aging fuel pump drawing extra curent as the ECM ups the voltage
to it to increase fuel pressue under higer load??? Just a guess on my part.
If you can run with a scan tool hooked up you can monitor your system
voltage.
Old Jan 9, 2009 | 07:45 AM
Dennis's Avatar
ud
I don't know if it applies to your old man's car (you should include all details about the car, including theyear, etc)..But it may need a firmware update..ask the dealer in your area and see (by VIN) if this one needs an ECM reflash...Mine did and performance was spot on afterwards.
Old Jan 9, 2009 | 08:57 AM
The Chris X's Avatar
Battery sounds like a good place to start.
Old Jan 9, 2009 | 11:21 AM
pilot76s's Avatar
ORIGINAL: Dennis
Ifyou look at the signature of my posts, it says 02 x-type.But it is a 2002... 150,000 miles stick,3.0 V6, bone stock, Babied all its life. Garaged all its life. i did have the intake manifold off to change the rear plugs but it was hesitating before that - - not as bad. i changed the "o-rings" to the intake ports too.Also, there is a breather line that split from the intake manifold to the airbox. i replaced it with rubber hosing which seemed to help it but it nowhas gotten worse.
- The New Guy
Old Jan 9, 2009 | 11:57 AM
Dennis's Avatar
ud
My bad...I guess I was blinded by the fact, LIKE ME, you have/had a freakin LR..and that anybody, but people like you and me would be actually into another British car..
So I think it might need the reflash then..check it out with a dealer.
Old Jan 9, 2009 | 12:05 PM
pilot76s's Avatar
ORIGINAL: Dennis
haha no prob. thanks for the help. i cant stop with the british cars.. it started with my 63 triumph spitfire - - what a nightmare it was/is. Im still trying tofigure outhow it possibly can have 25+ wires for the headlights/foglights
Old Jan 9, 2009 | 01:42 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Is this what you refer to pilot?
https://www.jaguarforums.com/m_85477/tm.htm
My limited knowledge with the lights dimming ewtc would lead me to probably the alternator / battery to, but there are much more knowledgable guys on this site who will be able to help soon I'm sure.
Good luck
Jim
Old Jan 9, 2009 | 03:13 PM
pilot76s's Avatar
Good news, took it to Advanced Auto Parts and had them do a battery test. Turns out it was bad and I replaced it. Runs like a top! Stock battery lasted 7 years. Bad news, Those batterys set you back 150 bucks. But better than the alternator or fuel pump right?
Thanks for the help everyone.
Old Jan 9, 2009 | 04:45 PM
Dennis's Avatar
ud
Kudo to Chris X..Nice call buddy
Old Jan 9, 2009 | 05:57 PM
adreasx's Avatar
I've got a '74 TR6 I'm working on. Electrical was not a strength for British Letland!
aholbro1
Dec 29, 2024 06:46 PM
Wolfy
May 28, 2024 08:06 AM
Bcrary3
Feb 21, 2023 04:29 AM
redrover41
23
Sep 25, 2015 01:33 PM
hen555
Sep 7, 2015 11:13 PM
